7010 stopped moving
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Topic: 7010 stopped moving
    Posted: 17 May 2025 at 5:59pm
My son was driving around the field just fine.  Stopped to adjust the cultivator to bring it back home.  Went from lo 4th to high 4th to drive on the road.  It started to move and then just stopped.
No grinding of gears.  It feels like it is going into gear on both hi/lo and individual gears.  A few weeks ago, I bought a new clutch cable and installed it but the clutch pressure feels good so I don't think it has to do with that.  We have driven it quite a bit since changing the clutch cable.
I don't know if this is meaningful but I can put the hi/lo and park shift lever into each gear without pushing on the clutch with the motor running.  While in gear, I did rev the motor up to see if it would even creep forward or backward but it does not move.  It does shake a bit when I rev the engine which may be meaningful.  I did check the transmission fluid and it has fluid showing on the dipstick.
I find it really odd that it just stopped all of a sudden.  Nothing prior to this indicated there was any kind of transmission problem or anything going bad.  I need some ideas on how to debug this further.  This is a power director 16 speed.
My first idea is that it has to do with hi/lo.  I changed the hi/lo cable two years ago so it is a new cable.  Because it started to move and stopped when he changed from hi to lo, makes me think it is hi/lo problem.  Could it be stuck in between hi/lo?
Any help is appreciated!
Edited by calico190xt68 - 17 May 2025 at 6:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2025 at 7:32pm
The most important question: does the power steering work?? YES or NO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2025 at 8:40pm
Power Steering is NOT working.  I turned tractor on and tried to turn the steering wheel right and left and it put up a lot of resistance and did not turn the front wheels.
Does this imply that the hydraulic pump has failed?  That would be way better than the power director failing.  I can check the hydraulic fluid too.  I don't see a leak though.
I looked at the cables in the floor and they all work as expected and are attached.
Edited by calico190xt68 - 17 May 2025 at 8:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2025 at 9:04pm
The torque limiter on the flywheel has failed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2025 at 9:24pm
That does not sound good. I assume the tractor has to be split? Can you buy a torque limiter? About what would that cost to fix if you were to do it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2025 at 11:38pm
Tractor must be split just ahead of the cab. Costs vary depending on what one does. I usually replace the rear crankshaft seal and pull the Power Director clutch out and reseal it too. Flat rate labor for all that about 12 to 15 hrs. Or you could roll it apart and replace the T.L. clutch disc only and throw it back together. Labor then about 8 hrs and parts maybe $500 bucks ??.  Haven't done one in a long time and after four years of nothing but inflation, I have no idea what parts cost anymore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2025 at 11:03am
Thanks for that labor fix info.  Since it is in front, you do not have to loosen the cab I take it?
What kind of surprises me is that this torque limiter just went bad without showing any signs beforehand.  I am used to having something kind of go bad slowly or at least start making some weird noises, or act differently.  it went from working great to not moving at all.
Agco is $175/hour but an Allis knowledgeable Indiana resource is more like $85-$100 an hour, I believe.
Looking at the Agco site, there is a spring, plate and disk assembly available.  Those 3 alone are about $1200.00 in total but not sure I need all of those parts.  Sounds like at a minimum, I need the disk assembly which is about $500.  I might as well have the crankshaft seal and PD seal replaced as you recommend.  Probably going to be about $3,000 is my guess.
Going to have to do it though.   Tractor runs too good to not repair it.  This is why we bought a 7020 tractor last year so we have a backup tractor that can pretty much do the same thing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2025 at 6:46am
Years ago I put a new clutch in what was then my Dad's 89 Dodge Diesel pick up, which I inherited. One day my wife was out in it ant it just quit as your 7010. The clutch was from South Bend Clutch and was a complete set up. at the time of failure there was probably less than 10,000 miles on it and the marking "Flywheel Side" was still readable on the lining. The driving center had torn from the disc. I contacted South Bend and inquired about warranty on the cheap "Made in China" disc that I'd gotten from them. Their claim was they didn't sell "Made in China" stuff, however "made in China was clearly stamped into the metal portion of the disc, which I sent them pictures of along with a picture of the failed driving collar. They would not stand behind there product. Needless to say I will NEVER use South Bend Clutch EVER again. Rick Corder sent me a disc that I put in, that was over 15 years ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2025 at 10:16am
I did a little more investigation into this problem.  I do not have PTO either.  In fact, the PTO lever won't stay engaged.  I tried to force it to be engaged and it still doesn't spin the PTO.  I don't have any steering as I reported.  I can turn the steering wheel but it just goes in circles and does not move the wheels either direction.  The steering wheel is hard to turn.  The motor sounds like something is engaging when I try to release the clutch or engage PTO and that causes the slight shaking.  I can raise the 3 PT.
I am not really sure why the power steering and PTO goes away with a Torque Limiter problem though.  That doesn't seem to be intuitive to me but there is obviously more dependencies than I know about.
It has an appointment next week for fixing with Agco.  Agco tech doesn't think it is a Power Director problem based upon his research and prior experience.  He said it has been 20 years since he has had to do this kind of fix, if it turns out to be the Torque Limiter.  I will report back what the final fix ends up being.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2025 at 11:40am
If it was TL failure, you would have NO hydraulics, as the TL turns everything from the back of the engine. 3pt being able to raise tells me it's something else.
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2025 at 12:41pm
Well, my son is the one that ran the checks so I will double check with him on the 3 Pt.  He gets in a hurry, leaves out details, skips steps, etc.  I will confirm that.
Thanks on explaining that the TL does run everything.  I need to go look at the diagrams to wrap my head around that.
PeteMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeteMN Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2025 at 11:18pm
Here a lot of guys buy a torque limiter disk and the steel plate from a reputable aftermarket supplier which lowers the cost.
lentsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2025 at 9:59pm
I don't  know about your 7010, but my 7000 has a small cover in the housing under the torque limiter that you can pry off with a screwdriver and see if there are pieces of metal there. ( Pieces of the TL)
WD,D15,190XT,7000,8010x2,7060,8070
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2025 at 11:05pm
Not on a 7010 or larger.
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2025 at 9:40am
I never got a chance to start the tractor and test the 3 point before it got picked up and taken to Agco dealer.  I believe they will be tearing into it next week so I will report back what they find.
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2025 at 11:10am
The 7010 has been split and the culprit discovered.
See pictures.
Here is the comment from the Agco Technician for those interested.
And yes someone has definitely been in there . They doubled up the belleville washer and then tried to shim it out with lock washers (those spacers have a .040 variation in height.). I'm guessing that's why if failed, it was too tight and had no give (( you know what its designed to do))
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2025 at 11:15am
Depending on how many hrs are on that torque limiter, I could speculate that it wasn't perfectly centered in the flywheel. They must be "seated in" upon fire up after being replaced. If they aren't slipped at least a little, the disc splines aren't centered with the clutch shaft causing a fairly quick failure and wear on the clutch shaft splines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2025 at 12:26pm
I have put about 800 hours on it over the 5 years I have had it and no new clutch work.  It had the Tachometer reset 700 hours before I got it but that doesn't mean it got the clutch reinstalled at the same time the engine got rebuilt.  Ironically, it seemed to run fine up until the time it stopped moving.  No slow degradation at all from the transmission.  It is like something just broke and created this damage.  I had used it for tillage work 4 years ago pulling a 4 bottom plow and each year there after.  I also used it with a disc and a cultivator each of the last 3 years.  So it has done some tillage work over the years redoing hay fields without much of a complaint.
I did ask that the main crank seal be replaced while it was apart as future insurance.  Not sure the final inspection has been done yet to see if other parts are damaged.  Will report back on the final findings.
