Need help on 8030 again
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Topic: Need help on 8030 again
    Posted: 16 May 2025 at 6:21pm
I broke the remote cable for the rear hydraulics. What is the best way to replace it. At 72 I don't work to well standing on my head anymore. I got one ordered from bunker hill. Nearest  AGCO dealer with one in stock was  3.5 hrs away.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2025 at 8:14am
No body talks about it but I've put B/H remote cables on 3 8000 series tractors and the groove for the end  is too large to fit in slot. I prefer to file 2 flats in the groove VS widening the slot. I really prefer they just fit!  Shift cables have all been good.
joe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joe Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2025 at 3:01pm
Just put 1 in a 7040 and it was the same deal, too big. I think I put 2 flats on it with an 1/8" die grinder. in the cab, and opened up the clamp up under the cab with a die grinder. Park cable and clutch cable was OK. Not sure on the small cables, I updated to the large cable.
Edited by joe - 19 May 2025 at 3:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2025 at 5:13pm
Large cable conversion for 7000 series came with a new anchor bracket as the larger cables were larger and thicker.
PeteMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeteMN Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2025 at 6:58pm
Yeah, I had the same problem putting one in our 8050 on Sat.  I thought the old one was a tight fit taking it out so I just squeezed the new one into place.  Next time I'll grind a little slot on the cable.  I took the plate and rubber boot off, but I don't think you'd have to.   Just lubricate the new cable with some silcone lube and pull it thru.  Don't tighten the clevis ends on all the way, you'll have to adjust them to get the enough travel to open the valve all the way.  I had borrowed a cable from the third remote handle and it finally broke so I ordered two cables.  I can't find the extra pair of clevis ends so I just put one new cable on for now, never use three remotes at the same time anyway.
joe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joe Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2025 at 8:19am
Yes. I ordered the new bracket for in the console, as well as the clamps for the valve from Agco. They (the cable) didn't quite fit the new brackets.
Edited by joe - 20 May 2025 at 8:53am
BunkerHillCables View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BunkerHillCables Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2025 at 12:48pm
I appreciate the feedback on these Allis Chalmers cables. Oddly enough, this was not a problem I had heard about before but after doing a deeper dive I do see the difference in our standard clamp hub and the OEM hub.
Our 60-00250, 60-00269 and 60-00344 cables have all been updated with a custom made hub to match the original cable and all future orders will ship with this updated hub.
If you've purchased this cable from us in the past and are having issues with it don't hesitate to give me a call, thanks!
-Kevin
Bunker Hill
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2025 at 3:43pm
Thank you for your reply. It's nice to know that someone actually cares about their product.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2025 at 5:05pm
I would also like to thank you for checking in to this. I received my cables today and had to file a little off before they would slip into the bracket
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2025 at 6:50pm
I have used the Bunker Hill products for several years and have found them to be an excellent cable alternative with great service and selection. I too have experienced difficulties with the groove fitment to the Allis clamp on the large,7000 series,remote cables. I just put a smaller diameter remote cable on an early 7060 the other day and it fit perfectly. I don't recall needing any remote cables for an 8000 series, so I can't comment about them. Great products at a reasonable price. Keep up the good work and thanks for responding to this site.
