International Harvester Cub
BuckSkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Topic: International Harvester Cub
    Posted: 16 May 2025 at 1:46pm
Saturday_22-March-2025
International Harvester Cub Lo-Boy w/One Arm Loader
1963-1967
Owned by Juvenile Barger of Resurrection City, Kentucky
Although not readily evident in these photos, as per the information in the links, several models of these small Internationals have the engine/hood offset to one side; these Model 1000 loaders only have a single arm so as to accommodate that offset.
https://farmallcub.com/community/threads/i-h-1000-loader.86661/
https://www.tractordata.com/farm-tractors/000/2/8/289-international-harvester-cub-lo-boy.html
Edited by BuckSkin - 16 May 2025 at 7:36pm
plummerscarin View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2025 at 6:01pm
We have 3 cubs. Never seen a loader for one
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2025 at 6:32pm
Did you click the links ? - One of them takes you to an article about that particular loader.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2025 at 7:12pm
linky no worky...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2025 at 7:33pm
hmmmmmm.....,
I tried at least five times to fix them and the web-address showing in the link box thingie is exactly correct.
I can copy it from there and paste it into the search bar and it immediately goes to either place.
When I click the "CLICK HERE" and the link fails, the address showing in the bar is exactly the same as what I am using...
Something ain't right for certain.
I pasted the addresses that are working for me in the body of the message so you guys should be able to copy/paste and get there.
The first link, the one about the loader, is well worth a look if only to see some guys Border Collie dogs; the loader information is good too.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2025 at 8:09pm
Grandfather on my Mom’s side had a standard Farmall Cub(not the lowboy version), had a 1 row cultivator on it, also a 1 bottom plow, but he never used that. Grew tomatoes, peppers, and parsley, and supplied grocery stores and restaurants on the west side of Madison Wisconsin for many years.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2025 at 8:39pm
Codger View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2025 at 8:47pm
They sure were popular around here for mowing duty. I've not seen one in any other type of work other than running an auger myself.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2025 at 9:56pm
Here in the Burley Tobacco capitol of the world, it's about 50/50 whether they have a belly-mower or mounted cultivators and side-dressers.
Post Options Post Options   Thanks (1) Thanks(1)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2025 at 9:58pm
One of ours serves duty with a 1 bottom plow for the gardens and cultivating sweet corn. Another is a non runner but had a few cultivator parts and the front depth control I use with the plow. Third is a Loboy my late FIL had. It has a mower deck he used many years. Was previously used for groundskeeping at Owen's Brush Co. prior to becoming OralB.
Neat discussion on the loader attachment.
Edited by plummerscarin - 16 May 2025 at 10:00pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2025 at 6:55am
Uncle had a Cub for a while but it was really worn out and a neighbor still has it for parts. It was replaced with a Farmall "A" as was very similar with the small tires, low stance, and offset steering wheel. Really nice for mowing. I repainted that one about the same time I did the "VAC", and "VAI" Case tractors we had in the family then.
That's All Folks!
This page was generated in 1.285 seconds.
