CA First Use - Lost Flip Ring Hitch Pin
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Topic: CA First Use - Lost Flip Ring Hitch Pin
    Posted: 16 May 2025 at 10:42am
First use of my CA in nearly 40 years was fairly successful (video maybe in a week or so). Mowed an overgrown field with a 6ft finish mower. Seemed like light work for it. Grass and sage was 3ft in spots. Cleared limbs and obstacles beforehand. I noticed it misses less under heavy load. One accident occurred without consequence...the left side lift arm came loose at the implement because the flip ring pin fell out...Hard to see how that happened. Is there a better pin type? AI says flip ring is better than the double wire bail pin in terms of falling out.
1952 CA13092
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2025 at 1:49pm
get a couple of large "R" clips (lots bigger than these) and drive it through until it's hanging, brush and limbs have never pulled mine out
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2025 at 2:18pm
Lost linchpin a couple of times harrowing. Now I use a bolt that I double nut. Works for me . Joe's idea looks good too.
Edited by ACinSC - 16 May 2025 at 2:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2025 at 2:21pm
Always thought those were even more loss prone, but never pushed one on that far...have lots of those, I may try it.
Edited by dfwallis - 16 May 2025 at 2:22pm
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2025 at 2:38pm
I would lose them too before I started pushing them all the way through
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2025 at 5:54pm
Grind off the lynch pin end a little so the lock ring crosses over it. Rotate the pull pin so the lynch pin is horizontal not vertical.
This page was generated in 0.058 seconds.
