WANTED 70244642 studs
dkattau View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dkattau Quote  Post ReplyReply Direct Link To This Post Topic: WANTED 70244642 studs
    Posted: 15 May 2025 at 12:40pm
Looking for two 70244642 studs that hold the 275 lb weight on the front of a 190 or 200.
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2025 at 7:33pm
I ended up getting a pair from McMaster-Carr. Let me know if you need the specs. of the originals. McMaster is a little different.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2025 at 8:12am
OEM's are 3/4" NC threads both ends, length is 4 3/4+", each end is threaded 1 3/8+"
Post Options Post Options   Thanks (0) Thanks(0)   Quote dkattau Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2025 at 8:30am
Thank you.
