Royal King regeneratin
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Topic: Royal King regeneratin
    Posted: 13 May 2025 at 9:52pm
I have a RK37 that I cannot get to go into Regeneration. 300 hrs on it and never has.
It will occasionally give the regen alert but when i try to start the regen it will not start.
I see several guys on the net actually taking the filter off and cleaning it. Is that a workable solution? can that do harm on the engine?
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2025 at 10:32pm
GOOGLE search...... this is different than the BOOK..
I had that on my RK37 a few weeks back and contacted the local service crew. They told me to park the tractor, start it and set the engine rpm at least to 2400 rpm and let it run without pushing the regen button. That will kick off a manual regen without any indicators illuminating. It took about 30 minutes or so but everything went back to normal. The exhaust was extremely hot and smelly during this time while the soot was being burned off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2025 at 8:55am
Thanks Steve that helps tremendously! I too called the local service center, but they never mentioned that. They did point out that the when the Manual says 'stop all functions' it means the hydraulics all must be in a neutral position.....i was leaving the rear lift in the up position. But correcting that did not help.
Wait for the Lord;
This page was generated in 0.170 seconds.
