WD Narrow front pedistal
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Topic: WD Narrow front pedistal
    Posted: 11 May 2025 at 8:07pm
UPDATE- it is sold!!
I have for sale a Front pedistal for a WD. I put a wide front on my WD some years ago. It was a good tight steering narrow front.
Located near Deep River Iowa. I can load it with the WD and loader probably.
I am asking $50 CASH for it at pick up.
Thanks
Mike Townsley
Edited by allischalmerguy - 21 May 2025 at 10:30pm
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2025 at 6:30am
I might just be interested in that.
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2025 at 8:06am
Are the WD and WD-45 pedestals the same?
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2025 at 8:35am
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2025 at 6:30pm
I believe the WD and WD45 are the same. A WC will bolt in, but is lighter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2025 at 11:03pm
The WD pedestal is SOLD. Thanks John for coming to pick it up today. I enjoyed my visit with you. I hope you get it installed on the long time family farm WD and it improves the steering!
Mike Townsley
Post Options Post Options   Thanks (1) Thanks(1)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2025 at 11:32pm
The 45 pedestal is heavier. Has more iron in it. They interchange fine.
jmrehn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmrehn Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2025 at 6:20am
Thank you Mike, Got this far with it yesterday,Got to figure out how to get it out of there now,and catch it.
53WD
Post Options Post Options   Thanks (1) Thanks(1)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2025 at 12:06pm
Some free advice (that is probably worth what you paid for it!).
I found the easiest way is to remove the left frame rail (left is easier so you don't have to mess with the belt pulley). After you get it loose, drive a chisel in to separate the frame rail.
Before you put a lot of pressure on the 8 bolts at the front of the frame rails, rap them a few times with a 3 lb. (or bigger) hammer to break some of the bond. They have probably been on there for close to 70 years and I have seen a lot of them broken off.
It looks like a lot easier job than it actually is.
