1941 Allis-Chalmers Model "B"
BuckSkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Topic: 1941 Allis-Chalmers Model "B"
    Posted: 10 May 2025 at 11:24pm
Saturday_22-March-2025
Owned by Will Milby of Greensburg, Kentucky
QUESTION:
I see two types of front axles on "B"s; the inverted "Texas Longhorn" style like the one pictured; and, a more normal adjustable style.
Is this difference in axles an option; or, is there a point in production where the inverted style stops and the normal style begins ?
Also, of all the many "B"s I have seen and photographed, I have yet to see a tricycle; was the "B" ever offered in tricycle ?
Thanks.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2025 at 5:11am
The adjustable front axle became an option in 1940, IIRR...
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2025 at 7:58am
the "wish bone" axle was the standard for years and probably on 90% of the Bs that were made.
Les Kerf View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2025 at 9:18am
Interesting Model B Smile
It still has hand brakes but also electric start. Obviously the alternator and distributor are an upgrade, but was the electric start torque tube ever offered with a hand brake Model B?
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2025 at 9:37am
im not sure there was a " starter torque tube".... i have seen a few tractors that had the starter "DELETE" kit and they just have a plug in the starter hole... an possibly no ring on the flywheel..
Alberta Phil View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2025 at 9:51am
I have a '39 B and the bell housing is smooth. No starter mounting and no ring gear on the flywheel.  '41 Deluxe had electric start.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2025 at 10:41am
Yup, this is what I was referring to. After ~84 years there is no telling what may have been swapped around though.
It's still a cool tractor Smile
