HD-5 Filters, Main clutch
BFC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BFC Quote  Post ReplyReply Direct Link To This Post Topic: HD-5 Filters, Main clutch
    Posted: 10 May 2025 at 8:02pm
Filter for original canister
Oil Filter Wix #51010
Fuel Filter Secondary Wix # 33511
Fuel Filter Primary Wix # 33010
Name all WIX
I did change main clutch from Rockford Clutch to Auburn Clutch. Operate as should.
Have great day!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2025 at 3:54pm
Updates across the HD5 line were common , from Vickers hydraulic pump to increased length of pin bosses on loader frame mount .
From 5 speed transmission to 4 speed and hi and low reverse gears
Early 5G loader frame used a box beam between loader arms , later went to a round tube with upper and lower formed plate which stiffened the full loader frame
