rebuilding a hand clutch on a WD/WD45
LarryWC In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryWC In Quote  Post ReplyReply Direct Link To This Post Topic: rebuilding a hand clutch on a WD/WD45
    Posted: 11 Nov 2010 at 2:17pm
Where, or WHO has the clutch disc's to rebuild a hand clutch?
OR, is this a "send out" thing?
www.allischalmersmuseum.com
KC-WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KC-WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2010 at 2:40pm
AGCO and not cheep!
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2010 at 4:15pm
Larry - Try to get a used one. A few years ago I needed new discs and a new disc was $150 each.  Go a whole clutch for $125 from Wayne's Salvage in El Paso, IL.  Also might try Doc's in Lacon, IL.  - AL
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2010 at 4:16pm
Larry you could get a good compleat used one like the one in my shop , Somewhere in that pile of parts .  Richard
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2010 at 4:42pm
I sheared the rivets from the disc to the hub on mine. $160 bucks each. Needless to say, I riveted them back together.
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2010 at 7:23pm
A company that sells/rebuilds brakes for OTR trucks might be able to fix it.  But, it won't be cheap.................FWIW
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2010 at 7:26pm
  we have new clutch disc available   1-800-254-3116
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2010 at 7:28pm
Yep, a place like Mutual Wheel can put new linings on em.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KC-WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 11:21am
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 3:36pm
Use 3 discs even in a WD.Plates are different thickness between 2-plate and 3-plate clutches,hubs aren't installed the same between the two either.What I'm saying is that you can't take good 2-plate discs and build a 3-plate clutch.
