Allis Chalmer Big Ten. I got Spark Gas butNo Start
MPReno98 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MPReno98 Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmer Big Ten. I got Spark Gas butNo Start
    Posted: 10 May 2025 at 11:16am
Sparking blue. Brand new plug.
New fuel line and fuel filter.
Gas is running through.
It cranks but won’t turn over.
Trying to adjust air mixture screw and floater needle valve as well as trying to manually pump the gas above the carburetor…
Had it almost start a few times but can’t quite find the right adjustments on those two and had a friend recommend taking the head off and grind the valve cause he thinks there’s not enough air compression in the motor…
What does all the experts here think? Trying to remodel this but before anything I wanna get it to start run and purrr!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2025 at 4:36pm
you can check compression and verify that..
another possibility is the KEY on the flywheel is damaged and the SPARK is occuring at the wrong time ??
