trailer deck
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Topic: trailer deck
    Posted: 08 May 2025 at 2:48pm
we have a 16 ft utility trailer that is about 25 years old. The deck was getting bad an punched one hole thru one board last month. I bought 10 - 2 x 8 pressure treated and let them set outside under the awning for a month to somewhat dry out.
I took the old boards off and the BOTTOM of the boards looks half way decent. I had painted the TOP with used oil 3-4 times in the past 6 years... Thats when we bought it and the deck was VERY DRY - CRACKING..
I painted the NEW 2 x 8 on one face and both sides laying in the driveway. My plan was to install that side DOWN, then paint the TOP with the used oil after installed... Now im wondering if the BOTTOM should be painted ?  Bottom of 20 year old boards looked pretty good.. Maybe the BOTTOM should be open so it can BREATH ?  Wonder if i should just install now with the OILED side UP ?  .....
anyone else notice the BOTTOM of their trailer boards compared to the TOP ??
Edited by steve(ill) - 08 May 2025 at 2:51pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2025 at 4:06pm
btms are always better since the sun don't get to them....
oil ALL 6 sides,x3 on the ends !, redo every 5 years
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2025 at 5:22pm
Same happened to my car trailer. My daughter was wanting to build raised bed gardens so they got repurposed. New deck on mine should last till I decide to replace the trailer
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2025 at 5:58am
Mine is steel, I just let the tractors oil the deck. Really wish they didn't though. Some more than others.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2025 at 6:12am
Haven't had time to redeck my skid steer trailer yet. Purchased the lumber and stripped the old. Loose layed the boards to haul a couple of tractors and such and one 2X10 is already bending along it's length. I'll "jack" it back straight this weekend as I bolt them down.
That's All Folks!
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2025 at 6:28am
Treated my 12' utility trailer with linseed oil because that's what I had. Probably needs another coat. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2025 at 6:27pm
I have not used it but was told Apitong oil is the way to go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2025 at 8:28pm
This is my skid steer trailer I'm decking today. The boards were purchased from Menard's less than a month ago and they are twisted and curled badly. I loose layed them on the trailer after stripping off the old and used the trailer a couple of times but today started to straighten them back out using the trailer as the platform.
Loose laid boards with the worst one shown with clamp setting but no pressure applied:
Same with clamp tight and just starting to deform the edge from the applied pressure. Second clamp, (Pony) is applying downward pressure removing "twist":
Porto power shoving on the other end to align it. Again the pressure is just enough to start to crush the boad edge:
Allowed to dwell for just over an hour and gave the clamp and porto power some additional force as board is relaxing:
Going to allow an overnight set and will see the results tomorrow morning. There is one more board shown here that is minor but is twisting. This will remove easily:
I have a trough out back I can stack lumber in and fill this with used engine oil. I may do that later when the boards have dried out. I'm putting this deck down with semi trailer decking screws and they both install and remove easily. Hopefully have this task wrapped on Monday as have a small excavator to bring in for service.
Edited by Codger - 09 May 2025 at 8:30pm
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2025 at 9:40pm
I got my boards at Menards also.. Worst one is not 1/2 inch off... but mine are only 16 ft long.. I have a cover lip at the front and rear that helps hold them DOWN... I did use a bar clamp to pull them tight against each other.. Screwed down each as i went... I didnt use the trailer screws.. I bolted two 2 x 4 onto two of the cross members under the deck at 4 and 12  ft...lip holds them down at 0 and 16 ft. ... then used green House deck screws to attach the floor to the 2 x 4...
Edited by steve(ill) - 09 May 2025 at 9:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2025 at 10:21pm
These were arrow straight when I purchased them, but wet. Had planned to install very shortly after bringing them to the shop but had paying jobs make entry so this got shoved to the back burner. I had stacked them on my old Mack truck frame with a spacer board perpendicular to allow air to dry them out and they are much dryer than original but a couple have taken to changing shape.
Ran out just before dark and gave the clamps another twist, and the porto power another tensioning. The boards are now all shoved together tightly. I'll let this go till morning and then hopefully they will be close enough to do as you stated and force them together while fastening down.
This trailer has a strip of steel welded to the bulkhead at the front but nothing at the rear except the edge of the 6" channel that is the closing panel. Prior to my ownership 23 years ago somebody bent this channel and I've got to straighten it before the deck boads will fit in the area. I cut all of them even and will use the skid steer and hydraulics to pull it out tomorrow. Also need to do some straightening and welding on the hinged ramps. Like the trailer a lot but rust is just about to put it down. Even the 2X6X3/16" wall tube frame has holes rotted in it, but nothing structural yet.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2025 at 4:50pm
Didn't take my phone with me this morning but the clamping did pretty fair on straightening the bent 2X10. I also put the 4 ton porto power against a tube xmember I welded in years ago for hauling forklifts and pushed the tailboard back out so it is now relatively even full width across the rear. I built up another couple of clamps and now have a pair on each side of the trailer. With the boards pulled tightly against one another, the remaing open space between them is 11.5" so going to run back to Menard's and purchas a 2X12 and leave everything forced together tightly. Also found a piece of 2X2X1/8 equal leg angle steel to make the closing panel across the rear. This will disallow the board edges from peeling off when something comes in contact with them. The boards do not set flush with the structural steel but rather are elevated about 1/4".
I'll finish this task tomorrow afternoon and move onto something else.
That's All Folks!
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2025 at 10:32pm
any one try presseure treated boards i have been wondering about that,   i need to do mine in the next year
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2025 at 10:48pm
yes... i bought pressure treated boards and they were WET.. Stacked them under the awning with spacer lath and set for a month. not completely dry but enough to acept oil. I painted the top and both sides, the ends, and 6 inches on the bottom of both ends where it sets on the rails.... that seem to be the areas of damage on the 20 year old boards i removed. I left the BOTTOM not painted with oil, thinking he boards could continue to dry thru the bottom.. I bolted two 2 x  4 to a couple of the cross braces so i would have something to SCREw to instead of drilling 50 holes in the braces for deck screws.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2025 at 7:16pm
I redecked my trail in 2000 with pressure treated from menards the slip into a pocket ath the front and have an angle bolted over the rear ends. I put thompsons water seal on them once back when new. No screws or bolts through just lay on the trailer cross beams. If you drill or screw through the boards they will rot. Sits out side all the time. I installed the boards the day I got from menards.theyll dry on the trailer and open up small gaps between. Water then drains off. Also always clean the trailer off when your done letting debris lay on it will cause rot. The first untreated boards lasted 16 years.
Edited by Dakota Dave - 14 May 2025 at 7:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2025 at 9:09pm
finished this a couple days ago... Pressure treated with 2 coats of used oil after letting boards dry for a month..
Edited by steve(ill) - 16 May 2025 at 7:36am
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2025 at 11:03pm
So... Lumber is made from Trees.
Trees are celluloid beings that grow in asymmetrical stance to suit the individual location and conditions of the very spot they sprouted.
That means, they're not only NOT straight, they're internally stressed.
Cut a trunk or limb into a log, put it on a sawmill, and make a laser-straight cut through it, and slide it off onto a flat surface.  It'll be 'kinda' straight.  Let it sit for a while, moisture comes out of the exposed surfaces, which shrink, mebbie crack... but the slab you cut will no longer be flat... or straight... because internal stresses which kept it standing up in it's original spot, were asymmetrical... meaning... it grew in such a way that allowed it to stay centered with gravity, even IF there's much heavier limbs and leafage on one side of the tree (the downhill side of a slope, for instance).
Once cut, the OTHER side of the tree is no longer holding that slab in it's original fashion, so it starts shrinking based on how it grew, not how you WANT it to be.
Dimensioned Lumber is nothing more than a slab that's been run through a mill to square up it's sides, top, and bottom.  Run that slab through, and you'll get a plank, but the plank will be losing moisture due to all the 'new exposure' that occurred following it's visit by the sawmill.
Some parts of the wood naturally lose moisture faster than others, so that nicely milled plank starts to respond to shrinking that's occurring in the areas that dry faster... and you get a crooked board.
The BEST way to 'beat' this with a trailer, would be to take the material, as SOON as you get it, and fit it into the trailer.  Reject the pieces with the 'bend' (meaning, buy extra pieces), so you don't have to heavily fight nature here... or if you're clamping, place a 2x4 across the top, and once clampled, screw the 2x4 to ALL the planks, to hold them in position... then add the next plank... and place another plank into the spot intended for next... screw it into the new, and all the old planks as well...
Another way to do it, is to use 2x4 lumber... they bend much easier.  I would STILL use deck-top blocking, clamps and wedges to get 'em in together... but they'll be much more inclined to pull it all in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2025 at 4:44am
The most unstable part of the tree is the pith or center.  Avoid using any boards with any part of the pith in it, and you will have less movement.  Kinda hard to do with PT wood, as the wood used for PT is a low grade, because it soaks up the treatment better than a higher grade board, kinda a catch 22, LOL. A good reference book is the encyclopedia of wood. it has several diagrams which show how a piece of wood cut from any angle, will shrink upon drying...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2025 at 5:57am
It is kind of an interesting process to see, and watch. When doing some radar upgrades at Mobile, AL I stopped by a plant that did the process for an impromptu tour. I want to say Louisiana-Pacific was the parent ownership. Large vats, or heated vessels with a lot of water nozzles incorporated. Kinda looked like a railroad tank car mounted several feet off the ground. Swinging end bells or doors that were shut and battened closed. Lots of staged, stacked, and prepped lumber ready to be placed into the vessels via forklift.
I remember there were four, or five of these things in total with only the one I looked into not being operated. Very hot atmosphere but everything was outdoors. The vessels operating were all emitting steam and a bit on the noisy side as there was a large stationary diesel engine running pumps moving the water. Circulated water was CCA, (copper chromated arsenic) charged from a large tank and sprayed into the vessels saturating the lumber within for some given time. The lumber was then allowed to cool, removed and staged/stacked for the next process which I believe was packaging/shipment.
That all was back in the early 1990's and from memory. Did work at Keesler AFB in Biloxi, MS, Mobile, AL, New Orleans, LA, and along the roads down there are a lot of treatment plants for pine lumber.
That's All Folks!
This page was generated in 0.746 seconds.
