WTB Emulsion tube/discharge jet
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Topic: WTB Emulsion tube/discharge jet
    Posted: 05 May 2025 at 5:54am
Looking for an emulsion tube (also called "main discharge jet") to replace the broken one in my B's carb.
It's the Zenith carb, on a 125 engine & the emulsion tube is originally a 45-2 although anything that'll fit ought to be better than the broken one which requires running at 90% choke!
Thanks, Dan
Stuck Farmer
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2025 at 6:39am
I have a bin full of carburetor parts. There were may different versions use in the various Zenith carburetors. If you could make it over to this side of the pond you could possibly match up what you need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2025 at 9:01am
Thanks Paul, not much chance of me getting over there any time soon sadly, much as I'd love to.  Can get a photo of the item needed if it's any help.
Carb I believe is a 61 AJ7 (part #211955, outline #9805)
Stuck Farmer
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2025 at 9:41am
Further to this & with thanks to Mike Z, I believe the 45 jet from a later carb won't fit as the threaded portion is directly under the hex whereas my 45-2 is threaded on the lower end away from the hex.
Will get a photo next time we're over with the tractor but fear this is going to limit my options further.
Stuck Farmer
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2025 at 9:48am
Yes: To get the correct part, I would need to almost have it here to see what I have in the parts bin. just a part number would not be any help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2025 at 10:07am
That's my fear, these old Zenith carbs look so simple and so "samey" at a glance (And I've seen folk have luck with "put togethers" of multiple broken ones) but when you get into them deeper there's a lot more variation.
Will give it a measure as well as photo when I next lay hands on it. If you have anything that looks similar available to sell at that point I may just chance it since the carb is essentially useless as it sits.
Only other timely & practical option being this side of the pond is a Scamazon copy carb which I'd like to avoid, much rather send money to the US than China Wink
Edited by ekjdm14 - 06 May 2025 at 10:12am
Stuck Farmer
This page was generated in 0.289 seconds.
