Followed Me Home
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Topic: Followed Me Home
    Posted: 04 May 2025 at 9:30pm
I have long coveted an Allis Model CA, this one sorta fell into my lap for cheap. Loader, aftermarket 3-Point.
The engine was lightly stuck but my 14 year old Grandson had it freed up the next day. The carburetor needs cleaned, etc. before trying to start.
It has some issues with the steering box.
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2025 at 9:39pm
CA steering box arm normally points UP... Yours points DOWN like a model B.... maybe to get it away from the loader frame ?
Post Options Post Options   Thanks (1) Thanks(1)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2025 at 9:43pm
Never seen a loader on a CA, neat find. Good luck with it and hope you get it going. The extra length arm is for extra leverage steering I’m assuming due to the extra weight of the loader?
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2025 at 6:16am
Not sure on that, extra length on the drop arm would surely = less leverage?
What's the score with the negative camber on the front end too, is that normally how the adjustable WFE would sit & the one on my B is just wore slap out? Looks like you've got wider automotive tires like I do but mine just rub at the top of the knee, basically straight up/down with no camber at all.
Love the loader set up, that & the 3 point would come in super useful about now! (and bits of your carb haha!)
Good luck getting her going, looking forward to seeing another small one live again
Stuck Farmer
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2025 at 6:36am
A loader on a CA: That's surely asking for steering gear issues. Whoever added that extra length has thing basswckwards. That lever needs to be shorter for extra leverage. If you plan on keeping the loaded on it, it looks to be a good place for a FarmerFix of a replacement power steering box from a car or light pickup.
 I suppose that the original front axle gave up from the abuse the loader added, since it was replace with a D12 axle, needing the arm to point down.
 If it was here that 3pt would be on the scrap heap, the only thing they are good for are pinched fingers and a bad back. Snap coupler is the best hitch ever produced
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2025 at 7:56am
Not sure what this steering box came from but it has massive amounts of slop. I like the idea of finding a power steering box to scab in there.
Thanks for pointing that out, I did not realize it was not a Model C axle; I have never so much as seen or touched a D12 so wouldn't have recognized it as such.
Trouble is, I own a half dozen 3pt implements and exactly one snap coupler two-bottom plow. Snap coupler tools are scarce as hen's teeth around these parts
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2025 at 8:06am
Yup. Less leverage
PaulB pointed out that this is a D12 axle so I guess that's just how they were made? Confused The wheels are definitely not stock Allis-Chalmers.
We hope to get some use out of it around the homestead for sure Smile If I had any spare carb parts I would send you some
We got it turning over freely with the starter now and found some sparks so now just need to get the carburetor to carbureting. Tongue
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2025 at 9:14am
Great stuff, didn't realise the WFE wasn't correct either. perhaps as Pauls says accounts for the drop arm & camber angle.
Lovely simple carbs to go through though, especially when the 200lb gorilla on the other end of the tools doesn't twist bits of them right in half lol
Power steering would be great if you can make it work, after all the hydraulic pump is already there so should be easy.
Edited by ekjdm14 - 05 May 2025 at 9:15am
Stuck Farmer
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2025 at 10:34am
Les,
Welcome to the CA club! You have several mods that will be interesting. What are your plans for the tractor? Sounds like you have a good helper to get it going!
 Chris and Cheryl
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2025 at 12:46pm
that 3 point will be VERY HANDY around a small homestead / farm.. I have a "home made" one on a B and  keep a blade on it.... 2-3-4 the tractors have sickle / belly mower / drag disc..
and the loader will come in hand.. Use ocasionally as a fork truck or to move small loads.. Not a FULL TIME LOADER... but VERY HANDY for light use on SMALL farm.
Worn out gear boxes are normall for the B- C tractors.. Not hard to disassemble and repair..... i assume Paul means you have a D12 gear box in addition to the axle.. Bigger than a B, but probably easy to disassemble.. parts may be a problem.
Edited by steve(ill) - 05 May 2025 at 12:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2025 at 3:05pm
No. That is a CA box farmerized to work with the D12 axle. The CA box is a little bit better than what B&C boxes are as the CA box has 2 pins to the B or C single pin, however not up to loader service by any means. The D10/12 box is only slightly better than a CA one and parts are next to impossible to find.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2025 at 6:51pm
Les,
 Chris and Cheryl
Plan is to just get it running and then evaluate what it can and cannot do. This is mostly a project for the Grandson to advance his skills. So far I am into it $200 and a tank of gas for my Son-in-law to haul it home.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2025 at 6:54pm
you got that much value in the HITCH or Rear Tires !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2025 at 7:48pm
Yup Smile
He also sent along all of the original snap coupler hitch parts. The battery was toast though LOL
It is still 6 Volt Positive ground, the generator appears to have a regulator rather than just a cutout switch. The ammeter shows discharge when the ignition is turned on as well as the headlights, so at least some of the wiring is functional. The starter spins the engine briskly with all of the spark plugs out.
The carburetor throttle shaft and choke shaft are stuck, we boiled the carburetor today and it is now soaking in ATF/Acetone mixture.
The engine oil looks good enough to run. Probably will change it first though.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2025 at 8:19pm
At any rate a pretty interesting tractor
Post Options Post Options   Thanks (1) Thanks(1)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2025 at 4:10am
Bargain at twice the price Les, highly envious. Glad your battery was dead though, that might have sent me over the edge! LOL
Joking aside that's a roaring deal, would definitely recommend changing oil before you run as a lot of the crap can settle out when they sit & make used up old oil look brand new. Might be the new oil blacks up pretty quick too once she stirs up the pan but cheaper to do a couple of changes than a rebuild.
Stuck Farmer
Post Options Post Options   Thanks (1) Thanks(1)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2025 at 9:53pm
We got it fired up today! The wiring is junk so we just hot-wired it. It still needs lots of TLC but it is very hopeful. My 14 year old Grandson did almost all of the work thus far.
Post Options Post Options   Thanks (1) Thanks(1)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2025 at 4:37am
Excellent, really good to hear the youngins getting stuck in as well.
Stuck Farmer
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2025 at 8:19pm
Progress report:
Grandson re-wired the CA and we fired it up today. The generator actually charges and the lights now work. Smile
I mentioned previously that it had an actual regulator system but I was wrong, it still uses the cutout relay and the light switch for regulation. The light switch looks like it could be the original, but it still works just fine.
We found a tag on the loader that reads: Wagner Iron Works WFA CA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2025 at 6:37pm
What are the distinguishing features that identify this as a D12 axle rather than a CA axle?
All of the tie rod ends are shot so I need to know exactly what I need for parts so as to fix that portion.
Thanks for the help Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2025 at 6:44pm
Grandson hooked onto an 8' disc with the 3-point hitch and disced their garden. He said the Traction Booster kicked in and lifted the disc when it started bogging the tractor down. The gauge is disconnected due to a broken pressure tube (it is pinched off so it doesn't leak). Will need to acquire an owner's manual so as to learn how to properly use that function. I don't personally know anyone who has ever used a Traction Booster Allis.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2025 at 7:01pm
The D12 front axle has a single tie rod between both sides with a connection in the middle from the bellcrank bolted to the left side of the main tube. Also the front axle support will be a flat plate, similar to a B, will a fabricated radiator support like a B unless it is a casting from a series III
 The CA WFE will have 2 tie rods connected to the arm under the front casting. The CA front casting will have the cultivator support mounts that will protrude through the grill shroud.
  Show us some pictures of the front end with the loader raised.
Edited by PaulB - 06 Jun 2025 at 7:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2025 at 8:33pm
Thank you Paul Smile
The loader is temporarily disabled; we are in the (slow) process of re-sealing the cylinders due to profuse leakage. I will get pictures when we get it back in action.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2025 at 8:37am
We removed the loader, hope these photos can help identify what we have here so I can know what tie rod ends to order.
And a frontal view
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2025 at 9:19am
I was mistaken, that is a CA wide Front. Is that a Power steering cylinder clamp to the tie rod or a steering stabilizer? In the first picture you posted at the beginning it looked like the drag ling connection there on the left side.
 A loader on a CA is not for heavy use by any means. A great recipe for a destroyed steering box.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2025 at 10:30am
I was mistaken, that is a CA wide Front. Is that a Power steering cylinder clamp to the tie rod or a steering stabilizer? ...
Thank you Paul; that gizmo is a steering stabilizer (shock absorber?). This loader will probably be set aside awaiting the future WD project.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2025 at 1:12pm
Welcome to the CA club!!  It is (IMHO) the greatest little tractor ever built.
Yes, that loader is WAY TOO much for the little CA.  Just the framework alone is awful heavy for a CA front.
They are a great tractor for disking, mowing hay, pulling any trailer, a Woods belly mower, and just an all around work horse, but they were never meant to use with a heavy loader.
You'll be very happy with it!
Especially since you stole it!  Can't believe.......$200!  I just put new tires and tubes on mine and it cost me more than that!
Enjoy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2025 at 2:15pm
Enjoy
Thank you Ted Smile
My late Father-in-law never tired of extolling the virtues of the Model CA that his Dad bought new after WW2. Due to rationing they had been on a waiting list for a Model C for a long time; by the time their turn came up the Model C had been discontinued so they bought a CA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2025 at 7:37pm
Grandson informed me that the 'new' CA is a Gear Jumper, 3rd gear of course Cry
This page was generated in 0.107 seconds.
