Neglected Allis Chalmers 720 TLB
Heliarc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heliarc Quote  Post ReplyReply Direct Link To This Post Topic: Neglected Allis Chalmers 720 TLB
    Posted: 04 May 2025 at 5:09pm
Brought this home yesterday. It's certainly a project but I think it'll be an awesome machine when it's up and running.
I figure I can do a better job showing what I go through on video. Seller said something about this is one of seventeen configured this way with a loader and backhoe. I don't know but once it's working it's going to be great!
https://youtu.be/1x5U2iTbxfs
Edited by Heliarc - 04 May 2025 at 5:12pm
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2025 at 10:38am
thats a neat set up,  take the heads off it might be locked up from carbon deposits on the head
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heliarc Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2025 at 1:13pm
Filled the cylinders with ATF/Seafoam. All I had was Seafoam so I figured can't hurt. Left it overnight. Took the cover off the shaft to the rear PTO and used a pipewrench on the shaft. It came loose with little effort. Back and forth a few times until it would roll all the way through, rolled it over ten more times then rolled it over a bunch on the starter. Right side compression is currently 90PSI, 115 on the left. I figure there's some junk in the rings on the right side.
