Need Moldboards
Pickin-Nick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pickin-Nick Quote  Post ReplyReply Direct Link To This Post Topic: Need Moldboards
    Posted: 11 Nov 2010 at 8:24am
Just salvaged a AC model 60 (4-14 snap coupler) from the scrapper, but i need 4 moldboards, shins and shares are useable.
Anybody have an suggestions?
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2010 at 8:51am
#'s off old parts ?
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2010 at 9:44am
Knowing the plow model only isolates the bottoms to AC parts. Need numbers from frog, moldboard, shin, or share to identify the bottom, then the possible moldboards can be identified and you have something specific to look for.
If its 4 bottom, its actually a model 64.
Gerald J.
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 6:37am
I would have the moldboards. $35.00 each. 785-353-2392
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pickin-Nick Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 1:26pm
there are no stamped numbers on the moldboard. there appears to be a 387 decal on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 2:00pm
The its probably a 387 bottom and moldboards can probably be had new from several vendors. Like SH34966 from Shoup (www.shoupparts.com).
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 2:35pm
Nick - you are lucky - 387 bottoms are about the only AC bottom you can reliably find aftermarket parts for.
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
This page was generated in 0.043 seconds.
