Landscaping Advice with Tractor Use – Bes |
arbordxb
Topic: Landscaping Advice with Tractor Use – BesPosted: 23 Apr 2025 at 8:08am |
Hi folks,
I'm starting a landscaping project and wanted to hear from others who’ve used tractors or similar equipment for this kind of work. We’re working on a mix of residential and commercial plots – mostly leveling ground, preparing soil, and laying out planting areas. I’d love some advice on:
Appreciate any tips or shared experiences—always something to learn from seasoned hands! Thanks in advance! |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42249 |
Posted: 02 May 2025 at 9:00am |
Rough or finish grading ?
For years I used a back blade on IH 460 Utility tractor along with rough grade with HD5G using bucket without teeth to smooth and level . Later I uses a land plane on my New Holland 785 skid loader , or just bucket on skid loader to smooth small areas . Using a Fiat Allis FD5 dozer now and finish with LX665 New Holland skid loader . Depending on how large of area your doing depends on machine , what size truck you have to transport and how heavy of jobs you take on . I started doing driveway rock and grading , then bought HD5G and started doing dirt moving and trucking , digging basements and backfill foundations . Next I got certification for On Site Septic Systems - Design , Install , Soil Testing , Repair , and Inspections . So equipment changes as added Tractor Loader Backhoe, 2 1/2 yard 4 wheel drive loader , and other machines as needed . But first 5 years was the IH 460 , HD5G , Tandem dump truck and low boy trailer to haul the HD5 - the 460 I could move behind pickup on 4 wheel trailer . INSURANCE cost will dictate work also as what you can insure at right price , The GVW of truck govern costs and if you need a CDL license . Insurance if you need XCU coverage or extended liability , product liability , and the array of other coverages . |
Les Kerf
Posted: 05 May 2025 at 8:18am |
I use a 3-point hitch box blade to level small areas and a 3-point hitch roto-tiller for preparing soil prior to planting. I'm curious as to what Allis-Chalmers equipment is available in Dubai?
BroseVino
Posted: 01 Aug 2025 at 8:29am |
I had a similar setup with my compact tractor and found it way easier once I got some grading done first to even out the low spots. I also used https://lookdevisservices.uk for a rough material estimate and it gave me a good starting point without overbuying gravel. Saved me a couple trips. Just make sure your box blade is set right and you'll be surprised how much smoother it gets.
Edited by BroseVino - 04 Aug 2025 at 9:49am |
