Allis 262 6 cyl Gas Engine-$1200
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: Allis 262 6 cyl Gas Engine-$1200
    Posted: 29 Apr 2025 at 6:18am
Has combine governor and front plate. Compression check shows 140 psi in all 6 cylinders. Oil pressure is 15 psi at idle. Manifolds are in great condition. It comes with carburetor but without the starter nor the rear steel plate nor flywheel. I will be pulling the engine May 1st or so. Until then, you could come hear it run.
Engine is located in Elk River, MN 55330 Can deliver along the I35 corridor from the Twin Cities to Albert Lea and also along Hwy 52 from the Twin Cities to Decorah, Ia
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
This page was generated in 0.053 seconds.
