Original All Crop Combine |
Collin Moore 2010
Topic: Original All Crop CombinePosted: 28 Apr 2025 at 7:54pm |
So I’ve been trying to learn more about the All Crop line and I was wondering if anyone has one of the original or first built All Crop combines. I would like to know if the clean grain elevator was also the elevator that loaded the grain tank sort of like some of the Massey Harris Clipper combines. If anyone knows other differences from the original machine to a more common one, that would be much appreciated too!
dkattau
Posted: 28 Apr 2025 at 9:57pm |
Yes. The clean grain elevator was also the unloading elevator prior to 1938.
Sherman Farms
Joined: 17 Sep 2009 Location: Centerburg, OH Points: 1683 |
Posted: 30 Apr 2025 at 9:19pm |
We have an operating original All Crop combine.
B, C, RC, 3 wc,2 wd,3 wd45, d15, d17, d19, d21, 190, 440, 7040, 918 backhoe, 12 roto balers, 7 60 combines, 40, 66,2 72,90 super, sp100, Gleaner E, F3, 3 L2, R62, and much more
Collin Moore 2010
Posted: 02 May 2025 at 6:40am |
Awesome! Is it like the ones in the pictures above?
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8474 |
Posted: 02 May 2025 at 8:24am |
While similar in design, there is very little in common as far as parts interchangeability between the early model you have pictured and a model 60. (Your first photo is a 1937, second and third are 1936) The combine was called the Corn Belt combine while in the experimental phase (early 30s), then when introduced as a production machine for 1935 it was named the High Speed combine. Some people will argue it was never called that, but I have advertising literature to prove it. In 1936 it was again renamed, this time to the All-Crop Harvester, and carried that name through 1937. In 1938 it underwent a significant redesign, and the model 40 was also introduced. Now that there were two models, they needed a number for them both, so the bigger one became the 60.
The original High Speed/All-Crop was a significant leap forward in harvester development, but it was still an archaic design. There was no gearbox disengagement, so the entire machine had to run while unloading the bin. Some of them had quick tension release idlers on the back of the separator so you could at least stop that part from operating, but the header and cylinder would remain running. There are a lot more nuances with them and they underwent a few changes throughout their production run such as decal design, straw hood design, and the big tailings recleaner you’ll see in two of your photos. I’ve never seen a 1935 model to verify if this actually went into production, but the patents show the “fish backs” on the straw rack were on hinges and they oscillated side to side as the straw rack moved back and forth to help further agitate grain. These machines not very common to find today, a lot were probably scrapped during WWII due to their obsolescence even by then. I hope to find one someday in nice condition to add to my own collection. Edited by CrestonM - 02 May 2025 at 8:38am |
Kip-Utah
Joined: 14 Sep 2009 Location: Southern Utah Points: 921 |
Posted: 02 May 2025 at 10:17am |
My great grandpa & grandpa bought an "All Crop Harvester" along with a new 1935 WC tractor and a plow in 1936. Their combine had the bagging platform instead of a bin. I know that it was decaled "All Crop". Years later they retired this combine for a good used bin model 60.
Joe(OH)
Joined: 11 Sep 2009 Location: Montezuma, Ohio Points: 1003 |
Posted: 02 May 2025 at 10:24am |
Life is simpler when you plow around the stump.
Joe(OH)
Posted: 02 May 2025 at 10:25am |
This is a picture of my grandpa with one. Story was he bought a WC and All-Crop in 1936. I know form family pictures that by July of 1938 he what looks like a regular model 60. I will try to post the picture of it too!
Joe(OH)
Posted: 02 May 2025 at 10:26am |
Sherman Farms
Posted: 02 May 2025 at 2:16pm |
Pretty much the same with a few minor changes.
Collin Moore 2010
Thanks(1)
Posted: 03 May 2025 at 7:39pm |
Wow! Thank you for all of the information! I always thought that they were called All Crops but now I know otherwise! The original ones sure are awesome and they certainly are not common. I personally own a 1948 all crop 60 that was sitting in a woods for 60+ years and I restored it. What makes this machine special is the sheet metal is made out of aluminum instead of normal iron sheet metal like you find on almost every machine. One negative about the aluminum models is they did not hold up quite as good as the iron models. The shield above the cylinder, not the one for the return grain, but the one that connects that shield to the top sheet metal was just about round and it should be flat. It also had a huge hole in it as well. The sheet metal directly behind the cylinder has some decent size dents in it from the inside, most likely from rocks. Also the sheet metal on the top of the separator behind the cylinder was also replaced at one point. Now the benefits of the aluminum sheet metal was it did not rot out like iron sheet metal. There was an identical 60 about 10 feet away from this one and it was completely gone. And when I say completely gone, I mean it left the woods in several pieces being carried by a tele handler. It was missing the tire and rim underneath the concave, and of course, stupid groundhogs collapsed into the ground so moisture basically rotted the thing to almost nothing. Many parts were robbed off it too like the PTO shaft along with some of the tongue. I got the useful parts off and then it made its way over to the scrapyard. 1,400 hours later and the aluminum model 60 was back in the field, doing an excellent job! I believe this machine was parked because the original owners bent the cylinder somehow and when I removed the cylinder bars, they were so bent out of shape. I don’t even know how it’s spun! So it’s pretty obvious the original owners did not care about it and I would say it ate a lot of rocks and its life. Other than that, I don’t see any other reasons why it was parked, and all of the bearings and bushings were and are in exceptionally good shape and I haven’t done anything to them except throw a little grease at them and the thing runs extremely smooth! I bought a model 66 as my parts machine to get this one back up and running and it was in let’s say fare shape for $500. However, the grain drag floor was completely rotted out and the bottom of the grain tank. But all of the parts that I needed were in great shape and I have since then parted that machine completely out, and it has made its way to the scrapyard as well. That machine also had a cylinder speed gauge which I know is quite rare nowadays and I had that rebuilt and it works great! Overall great machine, and I can’t wait to harvest wheat this year! Someday, maybe I’ll end up with an All Crop 90.
dkattau
Posted: 04 May 2025 at 2:23am |
It only takes one rock to bend a whole set of cylinder bars…
CrestonM
Posted: 05 May 2025 at 11:06am |
Congratulations on your undertaking! Good to see more young people involved in the hobby who appreciate the implements, not just tractors like you see more often than not. I fixed up a 1950 60A a few years ago when I was 18, and I still use it. I agree, a 90 would be a cool machine to have, but be aware if you do get one, parts are usually harder to come by since there were a lot fewer 90s produced than there were 60s. Personally, I really like the Super 100 self propelled. Not that they’re a very well designed combine from a maintenance standpoint, but they’re definitely unique.
Edited by CrestonM - 05 May 2025 at 11:07am |
Collin Moore 2010
Posted: 05 May 2025 at 7:44pm |
The 100s are pretty cool machines and they are very different compared to a more modern machine. Do they have a closed concave with rubber cylinder bars like the pull type machines? Or did they go to like a rasp bar and open concave design? Hopefully someday I can make it to the Orange Spectacular and see all of these machines in person. If I ever acquire a 90, it would be used to cut a little soy beans or wheat here and there, but otherwise it would be more of a showpiece. Not like the type of showpiece where it sits at the end of the driveway was Christmas lights on it because that really hurts me to see that. I would keep it in working order and pull it through parades more of less. There’s a local guy north of me about 20 minutes that has a huge collection of Allis Chalmers equipment. I drove by once and I saw multiple tractors, multiple All Crops and some other pull type combines, possibly Gleaners judging by the grain tank that’s up in the air. I have to make my way up there someday and see these machines in person. Maybe he’ll have a 90 that’s for sale! lol Anyways thanks for the responses!
CrestonM
Posted: 06 May 2025 at 7:44am |
The 100 has an open concave design but it still uses the same style of cylinder and concave bars that your 60 uses.
