Seeking recommendations………… |
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8406 |
Topic: Seeking recommendations…………Posted: 28 Apr 2025 at 6:54pm |
for residential water softener. Municipal water supply, and municipal sewer.
Will be placed in the laundry room, which is adjacent to a bedroom, do quietness of regeneration cycle is paramount. TIA. |
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90897 |
Posted: 28 Apr 2025 at 7:20pm |
you can set the regen time.. Normally is 1 or 2 in the morning since nobody is using water.. If the location is right by the bedroom, you might get up at 7 am, shower . breakfast... Then have it regen at 9 am or something like that ? 7 PM would be another good time while your watching TV ??
I think i got ours at MENARDS about 10 years ago... Seems like they last a long time..
Mnfarmboy
Bronze Level Access
Joined: 12 Sep 2009 Location: Edmond, Ok Points: 128 |
Posted: 28 Apr 2025 at 10:00pm |
I bought one from Amazon and installed it myself, TEIR 1 was the brand name. works well and does a great job of producing soft water. When mine regenerates I have no water in the house. Softners are available that put themselves in a bypass mode so you always have house water. Mine regenerates at 2:oo Am so not having water for a couple of hours is ok with us. Dave M
ac hunter
Posted: 29 Apr 2025 at 6:21am |
20 years ago we had to replace our softener and had a meter installed that bases regeneration on the volume of water used and not time. Cut down a lot on cycles and salt use.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42274 |
Posted: 03 May 2025 at 2:18pm |
Most new units go on total water use through rather than day of week and time of day .
The one I had also went into bypass mode when regenerating and did have a clock to set time to cycle - so little or no notice of it's operation . As I have well water and hardness is around 17grains - the recycle times depended on how much water use to reach settings for regeneration - could tell at times as well pump made more noise than softener - newer unit was a lot quieter than the first unit i had which had a clock and pins to set days of week on clock dial . |
