Hydraulic oil
Stoges View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stoges Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic oil
    Posted: 20 Apr 2025 at 8:18pm
Not using the hydraulic in a WD pulling tractor, do you need to keep oil in the system.
AintCheatnAintTryn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AintCheatnAintTryn Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2025 at 5:16pm
Most dedicated pulling tractors in my area drain the fluid and pull all the hydraulics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2025 at 6:16pm
This is a funny post. On April 20th you asked the same exact question and I told you there was a clutch shaft bearing inside that hydraulic compartment. Keeping 6 quarts of oil in there weighs 9 pounds and sees to it the bearing will never ever fail. Good luck !!
Edited by DrAllis - 06 May 2025 at 8:19pm
