D 15 PTO Shift Lever O Ring
Loren-ia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Loren-ia Quote  Post ReplyReply Direct Link To This Post Topic: D 15 PTO Shift Lever O Ring
    Posted: 20 Apr 2025 at 5:02pm
The O ring on the PTO shift lever on my D 15 series 2 needs to be replaced. Wondering if the tractor has to be split or can it be done through the torque housing cover.
Thanks for any advise.
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2025 at 6:44pm
I have been told by a retired AC mechanic that the arm/shaft can be pried to the left and roll an O-ring into place. I can't do that on. mine, no clearance between arm and housing! vGood luck!
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2025 at 8:33pm
Tractor must be split to replace that o-ring.
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2025 at 8:51pm
It can be done without splitting tractor. It isn't  the easiest job, but with ingenuity and patience it can be done. HTH Tracy
