Eaton 2-Speed ???
BuckSkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Topic: Eaton 2-Speed ???
    Posted: 16 Apr 2025 at 10:22pm
Sunday_13-April-2025
Greg's New C-65 Chevrolet
1975 w/427 and Air-Brakes
Please take note of the shifter-pole and the gear knob.
Of all the many trucks I have driven, I have never before seen an Eaton 2-Speed.
The engine is a Big Block 427 Gasoline
The bell-housing and transmission are HUGE.
Can anyone please tell us just what we have here as neither of us have ever seen one before.
If the pole is "five-speed" and then split, one would think it a 10-speed; however, every Eaton 10-speed I have ever driven (I hate them, by the way) has the T-handle range selector clamped on the pole and no button on the knob.
What do we have here ? Thanks.
Edited by BuckSkin - 19 Apr 2025 at 10:39pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2025 at 4:01am
The truck had been a Tandem at one time, had TWO Eaton Two Speed differentials shifted with Air not Vacuum or Electric, where in the 1970s there was a Attempt to make the two Individually capable of being shifted independently, IE Eaton Three Speed Rears.  Heavier gear box and bell housing was for that tandem load rate.
BTW Ford Super Duty 750/850 series were well known for the three speed setup, converted a great many to two speed control.
As a Add, 90% of all the HD Road Trucks had Eaton Fuller 8, 9, 10, 13 or 18 speed transmissions.  Learned to drive those in Freightliner Cabover with a 13.  Easy as Pie.
Edited by DMiller - 17 Apr 2025 at 4:03am
Codger View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2025 at 6:15am
Seen that setup on a couple of GM, and Ford products back in those days. Never did like it myself as when one shift set was worn, something got into a bind, (think driving two rear axles at different ratios) the result was usually destructive to drivelines. Usually behind a "Spicer" five speed transmission. Never seen the setup in diesel; always gasoline powered units being usually fertilizer, or fuel delivery trucks.
That's All Folks!
Lars(wi) View Drop Down
Post Options Post Options   Thanks (2) Thanks(2)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2025 at 6:58am
Best thing to do is, crawl under the truck and read the model number on the side of the transmission, then you know for sure what it is.
I myself, have operated a plethora of Eaton transmissions over the years, straight 5, 6, 7, 5+2, 8, 9, 10(the most common at the time), 13, 18(one my fav), and the Super 10. The worst is the Eaton Auto-Shift, absolutely miserable to use.
Edited by Lars(wi) - 17 Apr 2025 at 6:59am
Post Options Post Options   Thanks (1) Thanks(1)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2025 at 7:12pm
Now Eaton Three-speed Axles | 6th November 1964 | The Commercial Motor Archive
The Origination that failed and went to Two Speeds only.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2025 at 7:47pm
Those worked well; for a while till the wear set in and as mentioned, catastrophic failure. Usually replaced by two speed axles, or a 10 speed trans and single speed rears.
That's All Folks!
HudCo View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2025 at 8:02pm
looks like its missing some real importent parts
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2025 at 8:16pm
Them necessary pieces not shown in the photo are piled up on the other side of I guess that thing is a pontoon boat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2025 at 8:19pm
Do any of you guys know that truck ?
It belonged to Fritz's Garage and Towing of Lorain, Ohio; it had a huge wrecker bed with four big winches.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2025 at 8:39pm
Don't know the truck at all but in those days there weren't that many diesel trucks in medium duty service.
That's All Folks!
Post Options Post Options   Thanks (1) Thanks(1)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2025 at 2:42am
As Codger noted most of those days were Gas, 429 & 534 Ford, 366 & 427 GM, 504 & 549 IH, Dodge had the Industrial Hemis’. Massive Gas swillers.
DaveKamp View Drop Down
Post Options Post Options   Thanks (2) Thanks(2)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2025 at 9:34pm
Don't forget the GMC 478 V6...Wink
Post Options Post Options   Thanks (2) Thanks(2)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2025 at 4:00am
Or the GMC V12 gas truck engines. Hyattstown, MD. purchased 3 early 60s tilt cab trucks, 2 pumpers and a HD rescue when the new interstate was built north out of Washington DC. With their station located right at the end of an exit ramp, those 3 new trucks had specifications to be able to reach and maintain at least 100MPH even in the grades. Fuel mileage wasn't even an issue. Gas at that time was under $ .25 a gallon and those trucks had 2, 50 gallon tanks.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2025 at 7:33am
GM V6s were a Major PITA to work on, the 12s just added a second engine to that forest fire.  Spark Plugs in Engine Valley, shorter ignition circuits but also legendary garbage trough for debris to fall into opened holes and corrosion around plug threads.  Mice and other rodents built nests like Ft Knox as those sat starting lots of fires.  Could not keep Exhaust Manifolds on them for long.
1951WDNWWI View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1951WDNWWI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2025 at 6:45pm
Grew up in northern Wisconsin. What make was the two speed rear end on all those school buses?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2025 at 3:45am
Were only ever two major manufacturers US, Eaton and Spicer while GM constructed their own Corporate Axle in the 50s-70s, parts for those is rapidly attaining Unobtanium. Spicer owns Dana currently as Eaton Fuller owns several previous lines. Not many if any Two Speed differentials anymore with decreasing Gas Engine options, deeper torque curve diesels and Auto or semi-auto transmissions no longer a need.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2025 at 7:28am
Both of those brands are really the only ones that were common in the trucking arena. Bendix-Westinghouse used to market some also but I think they were actually Eaton design. Haven't seen a truck newer than early 80's that had a two speed axle myself although have seen some Rockwell, (Meritor) two speed axles in tandem setup for heavy haul work. Durability always depended upon the driver/operator. Lot's of problems with these with slip seat type operation where they did very well with a single operator.
That's All Folks!
This page was generated in 2.078 seconds.
