WANTED- 220 Drawbar
Jboehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jboehler Quote  Post ReplyReply Direct Link To This Post Topic: WANTED- 220 Drawbar
    Posted: 14 Apr 2025 at 7:21pm
Looking for a good Drawbar for my 220
Robert Musgrave View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Musgrave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2025 at 2:47pm
Anderson Tractor Supply, Bluffton, Ohio?
SyncPil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SyncPil Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2025 at 8:34pm
Have you managed to find any so far?
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2025 at 9:44pm
You probably know, but watch out for scammers contacting you with wanted to buy posts like this. Hopefully by now you got a lead on one from a long-time forum member with a good reputation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jboehler Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2025 at 1:30pm
No I havent found one yet.Thanks for the heads up on scammers I belive I have had a few scammers contact me about it.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2025 at 2:10pm
not sure if you're dead set on a stock one, but the ones from a 7000 series are straight, and fit nice, but will sit higher, and much more readily available.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2025 at 9:10pm
FYI, there were 2 different drawbars used depending if your tractor has a 3point hitch or not.  It might help for people to know which one you need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jboehler Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2025 at 7:08am
drawbar is for a tractor with 3 point.
WALLACE220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WALLACE220 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2025 at 8:37am
I have an extra one. It is bent up slightly
