A Question for the Machinists! |
Post Reply ![]() |
Page 12> |
EdK ![]() Silver Level ![]() ![]() Joined: 12 Sep 2009 Location: Newcastle, CA Points: 223 |
![]() ![]() ![]() ![]() ![]() Posted: 10 Nov 2010 at 3:02pm |
When I fabricate anything for my tractors, since
I do not weld, I need to make a lot of holes in metal so that they can be
bolted together. My problem is that a large diameter, (3/16 to 5/8 inch), drill
bit lasts for about 4 to 6 holes, then becomes extremely dull. I've tried
buying the best, (highest priced), drills at Home Depot, Lowe's and Ace
Hardware with no success. I've tried drilling with and without cutting
oil. I've tried stepping the holes up in size in hopes of putting less stress
on the bits. Nothing seems to help. Where do professional machinists purchase their
drill bits? Do they have the same problems I have keeping drill bits sharp
enough to drill metal?
DonDittmar ![]() Orange Level ![]() ![]() Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2516 |
Professional Machinsts usually sharpen there own bits on a bench grinder. |
1968 D15D,1962 D19D Also 1965 Cub Loboy and 1958 JD 720 Diesel Pony Start |
split51 ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Guthrie, OK Points: 713 |
I have had good luck with the cobalt bits from the Mac tool man but they are pricey. The good thing about the set is anything above 1/4" is lifetime warrantied.
1929 20-35 sn17662
B1 w/snow blade B10 w/sickle mower B110 w/mower deck B110 w/tiller B112 w/grader blade B210 w/plo |
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Cobalt bits are good but not necessary for the run of the mill steel you would be working with. If you can't sharpen a drill bit, they might help for a time. The hardest thing on a drill is running too fast, followed by trying to force a dull bit into the work. A properly sharpened drill bit is a wonderful thing. Learn how to sharpen them and when to sharpen them and save yourself a lot of time. Pay for my plane ticket and I'll come and show you how to sharpen one. LOL
TMiller/NC ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Lenoir, NC Points: 1776 |
We had a "Drill Doctor" that would sharpen up through 3/4", either 118 or the 135 degree split point. Works really well if the directions are followed to the letter.
M Diesel ![]() Silver Level ![]() Joined: 26 Feb 2010 Location: Las Vegas Points: 128 |
Well, agreed about fast but the hardest thing is getting them too hot, and high speed zooms up the temperature. They need to be run slow, and be generous with the cooling oil. Second big problem is almost always the bit pressure is too light to cut well and the associated bit chatter knocks the edges right off. Should have at least chips or preferably a pair of curls if things are completely right. A lot of factory bits will only cut a single curl though. And they should cut 50 holes without much change when treated well. 4 to 6 just means bad practice is at hand, and that can be remedied.
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5902 |
About a year ago I bought a 'Drill Doctor' drill bit sharpener when it was on sale for about $50. Model 350X . Does 3/32 up to 1/2"
It is about the best $50 I think I ever spent.
Over many years I had accumulated probably 100 'dull' drill bits.
Once I got the nack of using it, I sharpened every one to like new condition.
A 'must have' for anyone that is drilling steel.
I always use one of my 2 drill presses ( 1/2" and 3/4" ) whenever I can.
Having the correct drill speed (RPM ) and applying the correct steady pressure is important ( along with a SHARP drill bit )
Gary
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24714 |
When I read the original post I thought I'd written it !!! Glad I'm NOT the only guy with dull bits.The old Dormer brand bits lasted forever,sigh. Yes, oil helps a lot, and I have 2 coffee cans FULL of dull bits. Hopefully Santa will bring me a drill doctor....
Burgie ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Scottsburg, IN Points: 1192 |
Usually any drill bit that is anything can be sharpened to cut. Like what was said learn to sharpen the bits. I even have good luck with those China ones. Sharpening is the key.
"Burgie"
Pa.Pete ![]() Orange Level ![]() ![]() Joined: 01 Oct 2010 Points: 239 |
As stated before running to many RPM's is hard on them, pay attention to the chip it will tell everything, if you are running to fast they will be small and probally blue in color, you want a nice curl of both flutes, if you are only getting one chip it is only cutting on one side, make sure the cutting edges are the same length on both sides and that it is relieved (tapered down) from the cutting edge back. Also let off the pressure every few seconds to break the chip and you can't use too much cutting oil.
Hope this helps kind of hard to explain.
Pete
Bryan ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Illinois Points: 463 |
Ed, alot has to do with your drill speed. The bigger the hole the slower the drill speed. Some of the parts I machine at work, the holes are 6 mm and the spindle is running 9925 rpms.
Edited by Bryan - 10 Nov 2010 at 6:10pm |
BillinValpo ![]() Bronze Level ![]() ![]() Joined: 12 Sep 2009 Location: Valparaiso, In. Points: 40 |
Always remember speed kills with cutting tools. a constant force is needed and lots of oil. For the work you are doing a 135 degree split point works best. The drill doctor is a good machine. I have sold cutting tools for 30 years.
Gerald J. ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
I've been buying 135 degree split point drills from McMaster -Carr. www.mcmaster.com A 21/32" drill did about 60 holes in 1/2 and 3/4 steel with cutting oil (I use pipe threading oil for steel, though Mistic Metal Mover has a great reputation and I now own some but I've not opened the container yet), and no pilot holes. Turning about 450 RPM. That's just a hair over 5/8". The drill has a 1/2" shank with flats.
Gerald J. |
Formula for drill speed = 4 x cutting speed / diameter = RPM We used 80 fpm for cutting speed using high speed steel tools. For a 1/2" dia drill the formula would be............4 X 80 / 1/2= 320 / 1/2= 640 RPM. If I remember correctly from class 35 yrs ago. |
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
Ex BIL worked at McNeilus and when drilling holes in the truck frames for cement trucks and garbage trucks they went as fast and as hard as they could. Their bits lasted. I don't know what brand they used but they used and abused the heck out of them.
Wink I am a Russian Bot |
Butch(OH) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Lucerne Ohio Points: 3842 |
For those not inclined to get a calculator out to figure spindle RPMs a basic rule for any HSS cutting tool is to watch your chip color. Blue means tool is going bye bye in the next 5 seconds if you dont slow down. Gold means you have a couple more seconds to get it slowed down. Straw means your pushing your luck but you might get awat with it. No color is safe. With Colbalt your safe range goes into the straw color. Carbide is sparks, LOL.
Gatz in NE ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Lincoln, NE Points: 1060 |
Not using the correct RPM is usually the reason for drills to dull; especially as quickly as you've described. You didnt say what kind of machine you were using, but whatever it is, it must have some method of varying the spindle RPM to match the diameter of the drill and the material (SFM)
Some other factors are; rigidity, coolant (cutting oil) and feed rate or downward pressure.
Read through this to get a better understanding of how the material, drill size and RPM are inter-related.
Here's a site that you can practice by just entering some values to see how the related values change. You can get the SFM from the above site.
There are many other online sites for this topic...just type in
rpm calculator for drill
Edited by Gatz in NE - 10 Nov 2010 at 10:25pm |
Dave A ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Almond Wisconsi Points: 855 |
speed kills cutting tools. also not all drill bits are a like. some have a 118 degree tip some are 135 and some 90. Try the 118 degree tip with not a lot of back rake (to much back rake will cause the bit to chip on steal) and use good cutting oil. When sharping the bit aline the grinding wheel with the flite and sharpen cutting edge to heal. The amount you take off the heal is called back rake the moke you take off the faster the bit cuts but it also weekens the cutting edge if too much is taken . on the bigger bit some guys will cut some of the back side of the cutting edge flite off to help chips remove with alot a heat
Edited by Dave A - 11 Nov 2010 at 6:50am |
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill |
I guess I typed my reponse before fully understanding the question. Bought a set from Snap-on once, the only Snap-on tool I hated, they sucked. The best set I bought was from a flea market vendor at a tractor show, called Winters Drill Bit City. They cut good, been sharpened many times over in the drill doctor. I broke a few, but that was no fault to the bit, operator error.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88064 |
i have the drill press set about 400 RPM and nver change it. Been that way for 30 years. I have to get a small set up to 3/8 inch every 5-6 years due to breakage or kids using them.. My 1/2 inch to 1 inch drills have been there for 30 years. I sharpen each once or twice a year. You dont have to run fast to cut good. Cutting a little slow dont hurt. I seldom use oil unless the stuff is real hard. Pilot holes help when drilling 1-2 to 1 inch holes.
With the blunt center of the standard 118 degree grind, pilot holes are absolutely necessary. The split point 135 degree cuts to the center and doesn't benefit from a pilot hole.
Turning small drills slowly is why you break them, from expecting them to remove metal with that very slow speed at the cutting edge. You put too much pressure on them and they take too deep a cut. Gerald J. |
Dick L ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
Actually giving "proper" speed, "proper" down pressure are only guide lines. Along with had sharpening drill bits on a bench grinder, which I have been doing for over 50 years, is something you have to learn a feel for. I had to make a part out of pre hard steel yesterday that took three trips to the bench grinder with a high speed steel drill bit. I couldn't find a carbide in the correct size. You learn the amount of rake it takes for the different steels or you make extra trips to the bench grinder. I haven't seen a drill doctor that could figure the different rake for different drilling jobs.
I buy mostly high speed steel drill bits and work in mostly pre hard mold steel. I bought a few sets of cobalt in the past in both drill bits and mill cutters. I keep some carbide around but mostly in insert cutters.
I might add all drill doctors are not equal. Our purchasing agent where I used to work bought one from the Snap-On guy several years ago. It never worked on one bit. The relief would start going back up about half way back. Burnt heals was all I ever got out of it. For some reason our PA didn't want to mess with getting it replaced so it was back to the post grinder.
Brian Jasper co. Ia ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
The best set of drills I've found for us ordinary non machinist guys are Rodman brand. They have some sort of really hard inserted tip in them. I've found that I can use them to dress an ordinary grinder wheel. It takes a diamond wheel to sharpen them. As soon as i saw the guy selling them poke holes in a file, I figured that was a bit that would hold it's edge. Nice thing about them is they are life time guaranteed. Break them, knock the tip off, they replace them free. I do remember the guy saying a drill doctor would work well on them if it had a diamond wheel in it. |
firebrick43 ![]() Orange Level ![]() Joined: 10 Dec 2009 Location: Warren County Points: 592 |
Is you drill press in decent shape? Runout/spindle play is death to drill bits. Its amazing to double or even triple speeds and feeds with good ridged and powerful equipment with good coolant flow and get improved tool life to boot.
If you are doing low run type stuff Enco is a decent place to buy consumables for a decent price. Not crap but not high quality either. For multiple holes in a production enviroment you need mist/flood cooling and carbide tooling. We have some drills in the 1" range at work made of solid carbide that cost 900 dollars a piece. The can drill twice as fast and last 8-10 times as long(unless they hit a sl*g pocket) so they are worth it. Boy is it spectacular when they do explode Some steels it imparitive to keep them cool so they don't harden, especially stainless. Cutting to slow/without coolant is death to bits in this type of metal. Cutting to slow with bits results in breakage. |
BobHnwO ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Jenera Ohio Points: 693 |
I use Mobil 1 for cutting oil,works great,bits stay sharp longer.
mlpankey ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
i use plain water seams that i am more wastefull with it since it doesnt cost as much and the more i waste the cooler the bit stays.
Edited by mlpankey - 11 Nov 2010 at 2:50pm |
GBACBFan ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Green Bay WI Points: 2662 |
I've had really good luck with Oatey clear thread cutting oil. It's around 6 bucks a 16oz bottle at our local Menards, and is easy to apply at the point of the drill.
are genuine." - Mark Twain |
Having several blacksmiths in the family history, I like that. Just needs to be cool. "Cutting oil" kinda rankles my dad at times. Gotta say that water isn't all that friendly at times. I don't drill enough any more to worry about cost. For just some only kinda partly somewhat related info, the latest circuit board drills are now running over 400,000 rpm with 1,000,000 expected soon. Unbelievable feet per second past the spindle. Air cooled.
ChuckLuedtkeSEWI ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Jackson, WI Points: 1826 |
Are you using a drill press? Drill bits in a drill press always seem to last longer for me then using them in a corded/cordless drill. Keeps the bit straight and true. On my D17, when I drilled out the rear hubs and put in wheel studs, I drilled by hand, and went through drill bits like crazy. Sharpened them alot, but alot broke as I was drilling by hand. I was almost tempted to take the time and take it all apart, drill in the drill press and then put back together. Would have taken some time, but would have saved it clamping and drilling properly in the drill press. I just drilled some 1/2" holes in 5/8" plate for some loader mounts and I did them in the drill press. 12 holes, did them in about 15 minutes. Started with an 1/8" then 1/4" then the 1/2". Same drill bit on all the holes. I keep my drill press on the slowest setting all the time as well. Just make sure you're material is clamped or secured properly. I have a finger that the tip was sliced off on my dad's drill press when I was about 12. Tough lesson to learn but I never forgot it.
Edited by ChuckLuedtkeSEWI - 11 Nov 2010 at 6:16pm |
Post Reply ![]() |
Page 12> |
