D21 fuel issues |
acplowboy45
Joined: 09 May 2013 Location: connersville IN Points: 264 |
Topic: D21 fuel issuesPosted: 13 Apr 2025 at 1:10am |
Fuel issues I have been dealing with for the past 2 weeks off and on. It will start right up even after sitting a couple of days. Run it drive it down the road and by the time I get back to barn it dies runs the fuel filter dry. Now bowl in back of tank is clean. The break in the line I can take it off and it will pee a stream of fuel every time. I have blew out the return line and there clean. I can pour fuel into the top of filter canister prime it up a little bit and will start right back up. What am I missing.
DrAllis
Posted: 13 Apr 2025 at 3:36am |
Blow backwards into the tank. The outlet to the tank is plugged or hand primer has a blockage.
Edited by DrAllis - 13 Apr 2025 at 6:55am |
Straanger
Posted: 13 Apr 2025 at 10:59am |
Leave the fuel cap loose and try it again
acplowboy45
Posted: 13 Apr 2025 at 12:17pm |
I have left fuel cap loose and blew both ways into fuel tank. It's still wants to drain fuel filter. I'm thinking I need to replace plunger would that cause problems?
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1340 |
Posted: 13 Apr 2025 at 2:50pm |
Drain the tank and look down in it, might be something that sucks down and it releases after it’s shut down…
den/southern illinoi
Joined: 11 Sep 2009 Location: Sparta, Illinoi Points: 2092 |
Posted: 13 Apr 2025 at 4:37pm |
May not be the problem but we had a used skid steer that we were testing and after running a while it would shut down. Upon inspection there was a stick (someone's fuel gauge) in the tank that would float to the fuel intake and shut off the fuel flow. We ended up opting for a new skid steer.
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor. |
Codger
Posted: 13 Apr 2025 at 4:53pm |
I have seen that happen with a polypropylene cloth shop towel dropped into the tank more than once.
That's All Folks!
wjohn
Posted: 13 Apr 2025 at 4:57pm |
Not at all a diesel, but I had a very similar fuel issue on my Super M. There were multiple dead moths semi-suspened in the fuel tank that would eventually get drawn to the outlet and starve the tractor. If I let it sit for 10 minutes the moth carcasses would eventually drift/float away from the outlet and it would fill the carb again. Blowing air through the fuel line obviously didn't get rid of them for long and they would just keep getting drawn into the outlet until I figured out what was going on and pulled them out.
I'm not familiar with D21s at all but I would do my best to shine a light, bore scope, whatever you can do down the tank to make 100% sure there isn't a piece of junk in there before I tore anything down. Then work forward in the fuel system from there. Sounds like you have ruled several things out already.
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 722 |
Posted: 13 Apr 2025 at 5:28pm |
Neighbor had a 1566. It did the same thing. Turned out there was a golf ball in the tank. It would suck down and cover the outlet. When it cut cut off it would pop back away. Bleed it and it would run a while longer. Neither here nor there
Just a story
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5469 |
Posted: 13 Apr 2025 at 8:17pm |
Aluminum foil from a bottle of fuel additive stopped our 6060 when it got down to 1/8th-1/4 of a tank of fuel. Put more fuel in it and it ran fine. Finally pulled the tank later that summer and flushed it out. Quite shocked that the dime size piece of foil caused such a problem. Sounds like you may have something in there for sure as others have said. Just letting you know what happened to us.
acplowboy45
Posted: 13 Apr 2025 at 10:05pm |
Anyone have a decent used fuel tank for a D21 for sale. I have pulled this tank off flushed it. It did have some rust build up from sitting. I guess I'm going to have to pull tank back off and start over...STILL ANY USED D21 TANKS..PLEASE LET ME KNOW. Thanks for your help guys.
DrAllis
Posted: 13 Apr 2025 at 10:46pm |
You've had the tank off once already ?? Did you use a power washer and aim it in thru the fill hole?? and then aim it in thru each sediment bowl hole (sediment bowls removed) and drain/flush?? doing this more than once ?? I've only seen one tank bad enough that this method wouldn't work. The tractor (220) had been sitting 25 or so years. I feel it was going to require tank removal, cut open each end of the tank and clean with a power washer from each end or maybe sand blast too. It also may have required cutting the tank open underneath where the seat suspension track is and doing the same thing. Any good semi truck repair shop works on truck fuel tanks can do this. Each location is out of sight when the piece removed is welded back in place. The paint will match when you get done. I sold this tractor with the new owner knowing this. Don't know what he did for sure. EDIT: You should be able to look in thru the fill neck and get a good idea what it's like on that end of the tank. I would cut open the opposite (right) end first and see if that might be enough to get her cleaned out before cutting open both ends and the seat track area.
Edited by DrAllis - 14 Apr 2025 at 6:16am |
JimWenigOH
Posted: 15 Apr 2025 at 11:23am |
I had a similar issue with my 220. After running down the road for 8-10 mile it would act like it was running out of fuel (which it was) and eventually die. I'd pull over, try to pump the primer pump which was very stiff. Seems the injector pump was pulling a vacuum on the primer pump due to an internal check valve in the primer pump which was not working properly. Tried the loose fuel cap deal which didn't help. Installed a new primer pump and it's been working properly for the past 13 years.
