Milking Time |
Les Kerf
Topic: Milking TimePosted: 12 Apr 2025 at 10:35pm |
Grandsons using the Model C to power the Surge milking machine. If you look closely you can see the radiator shutters inside the grill. Thank you Paul B ![]() ![]() |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3951 |
Posted: 12 Apr 2025 at 11:02pm |
thats how we done it when the power whent out except we used the 66 chev pickup
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8684 |
Posted: 13 Apr 2025 at 12:26am |
What's the deal? Just drive the milker to Betsy and do the deed? No stanchen or barn needed.
Edited by SteveM C/IL - 13 Apr 2025 at 12:27am |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54450 |
Posted: 13 Apr 2025 at 4:31am |
That's what I would call a cow-er take off...
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5059 |
Posted: 13 Apr 2025 at 5:45am |
Dad had a hose that ran from the tractor to the vacuum line in the barn for when we lost power. IIRC, we could only run two milkers, instead of the four we usually used, but it was a lot better than milking by hand!
Stan R
Posted: 13 Apr 2025 at 6:09am |
My dad had a milking machine petcock on the CA intake manifold also. It was used every couple years, usually after a lightning storm knocked out the power. I can't recall if it kept one or two milking machines going.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5163 |
Posted: 13 Apr 2025 at 6:54am |
Glad to help with the shutters
What are those side frame mounts for? They look to be quite substantial.
Les Kerf
Posted: 13 Apr 2025 at 10:27am |
This tractor came to me with a bodacious front end loader that a previous owner had installed; it kinda-sorta worked but is really too heavy for a Model C. I left the mounts on to function as engine weights.
