seized spark plugs |
cowkicker
Topic: seized spark plugsPosted: 12 Apr 2025 at 5:14pm |
Looking for suggestions on removing spark plugs from a 1997 mountaineer 5.0 with cast iron heads. Tried to remove two of them and wasn't even able to turn them any, did crack the porcelain on one of them. Letting them soak with PB blaster now, all that I have at the moment. Suggestions???
DrAllis
Thanks(1)
Posted: 12 Apr 2025 at 5:48pm |
Have the engine WARM. Always warm.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90812 |
Posted: 12 Apr 2025 at 6:04pm |
heat and soak with oil is about the best you can do... If all else fails, i would try an impact.. 1000 small WACKS is better than a constant PULL trying to get something loose.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 13 Apr 2025 at 7:04am |
If it has those taper seat spark plugs, they are very common to seize in the heads. Not one of FORDs better ideas (like most of FORDs wacked ideas). I give them a "bump" with an impact to loosen them.
ekjdm14
Joined: 20 Aug 2024 Location: Alsager UK Points: 987 |
Posted: 13 Apr 2025 at 11:22am |
Pretty much all been said above, heat is essential. If just having the engine hot doesn't help, heat each one smoking hot with a blowtorch & douse with PB or similar.
Impact if you can get in there, if you break the plug off after heat/soak with the impact then it was going to break anyway.
Stuck Farmer
cowkicker
Thanks(2)
Posted: 13 Apr 2025 at 12:17pm |
Soaked them, warmed engine up, 3/8 impact on lowest setting, after a bit of hammering, they turned loose. Thanks
