WD lift arms will go up but won't lift anything
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Topic: WD lift arms will go up but won't lift anything
    Posted: 11 Apr 2025 at 7:30pm
My neighbor just got his new-to-him WD going.  The lift arms will go up when the control lever is raised, but I can push them back down while the pump is running or I can hold them down and keep them from raising.  Hold detent doesn't seem to hold.
This tractor has been sitting for quite a few years before he got it.
It had a loader on it that was plumbed into the rear remote and the control valves are mounted on the right fender.  He doesn't need the loader so I'm thinking that all that extra plumbing should be removed and see if that is causing this issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2025 at 7:38pm
YUP.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2025 at 7:05pm
The issue is that the oil is flowing with no restriction. I know that doesn’t explain the hold detent, but the lift arms have no pressure until you use the valve for the loader. Then I bet the arms will lift something then. Unhook the loader hydraulics from the rear is probably all you need to do. Hold detent is a separate issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2025 at 7:32pm
You were right!  Disconnected the hoses from the remote outlet and with a little bit of adjustment of the linkages, it seems to work as it should.  He's going to hook up to the rear blade and see how it lifts and holds.
