8030 steering
aunt allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aunt allis Quote  Post ReplyReply Direct Link To This Post Topic: 8030 steering
    Posted: 11 Apr 2025 at 7:41am
So I'm back working on FWA 8030. The spline was stripped out of steering pump (as some of you suggested) and I was able to get used parts. I put everything together and it steers normal. I drove it around the yard and happy with the results BUT, when I drove it back to the  customer, by the time I got to his place, I can barely turn the steering wheel. It seems like once the oil warmed up, it lost the power steering. Where do I look next?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2025 at 8:47am
Make da## sure the oil in the rear end is up to the TOP sight glass when sitting on the level engine OFF for 15 minutes. This is the first check.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aunt allis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2025 at 2:37pm
Ok thanks, I will double ck that
