Off Color Massey 36 Hay Rake - Woven Bushings?
wjohn View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Topic: Off Color Massey 36 Hay Rake - Woven Bushings?
    Posted: 10 Apr 2025 at 10:52pm
I am taking a $50 Massey-Harris Ferguson 36 hay rake that was destined for scrap and dumping too much time and money into it. I have heard these were decent rakes and this one is a 6 bar to boot. One of the main things it needs is attention to the axle shaft bushings to the main frame. There was a lot of play, some of which is from wear on the shaft and some is from wear in the bushings.
I have never seen bushings like these before. They have a metal casing (which is worn very oblong) much like the original oil seals common on our tractors, which is pressed into the hub casting. The bushing material inside that casing is some kind of woven... nylon, cotton, or something similar. It reminds me of the webbing around gas tank mounting on some of these old tractors, except much thicker. At first I thought it was a farmer fix until I found a picture of a NOS bushing on eBay that has this exact design (recently sold).
Anyone seen bushings like this before? Any ideas for replacement material I could cut and put in there? Or, would you just remove them completely and replace with an Oilite bushing or similar? There is a grease zerk to lubricate them.
tom51 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom51 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2025 at 11:18pm
Packing for a slurred pump
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2025 at 12:02am
Can't think of the name but its Poly something sort of like a plastic material that bushings were made of for the Besser Block machine we ran to replace the original bronze bushings that needed to be greased.The poly bushings were not greased and would outlast the bronze bushings greased.Check with McMaster Carr they probably have some that'd work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2025 at 12:09am
Google sewage pump gland packing. It’s a graphite rope.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2025 at 7:13am
for what you are starting with, how about finding PVC pipe that will press into the hub? It might need a piece inside of a piece to take up the clearance, but it would be cheap to see how it works.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2025 at 9:59am
Maybe try wooden bushings? I have al OLD field disc that uses maple bearings (bushings).
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2025 at 8:24pm
Thanks for all of the ideas and sorry I never followed up with this thread. I got buried getting the combine ready in time for wheat harvest, and then the weeds were so bad that I didn't bother baling any straw. The rake got shoved to the side, but not before I wound up locating some NOS axle support castings that had new bushings in them. I need to put it back together at some point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2025 at 9:12pm
Delrin AR is what you want. Tracy
ecosse23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ecosse23 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2025 at 3:35pm
Is Delrin the trade name for acetal? I have in my mind the pale coloured thermosetting plastic that gears and bushings are sometimes made from, think it’s tricky to machine.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2025 at 3:59pm
Its not hard to machine at all. Ive turned it bored it and tapped it
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote ecosse23 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2025 at 3:16am
I’m maybe thinking of another plastic called Tufnol?? Definitely remember having to be careful about the type of drill bit and limiting the temperature the plastic reached while working on it.
This page was generated in 0.115 seconds.
