Sway Blocks
Mike ( WI ) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike ( WI ) Quote  Post ReplyReply Direct Link To This Post Topic: Sway Blocks
    Posted: 10 Nov 2010 at 10:14am
I am trying to find a pair of sway blocks for a catagory 1 hitch for a Allis Chalmers 170 tractor I already checked with Brenda at Sandy Lake Impl. and she can only get one side the other side is no longer available. does any one know or have a set ?
Thanks!!
BillinValpo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillinValpo Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2010 at 6:13pm
Good luck I have been that route. Try Norm in Bourbon In.
caRon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2010 at 6:24pm
I have 2 sets, can't remember if their cat 1 or 2. Nice not rusty. I have pics, but their on the old computer. Will look. Ron
CA Tractor
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2010 at 8:57pm
i have some also,let me know if ron cant take of you
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 5:53am
If you just need for a short time usage you can bolt several layers of strap steel  to limit side movement of arms.  Weld several layers to make the same thickness as upper area.  I did this on a 170 until I located Cat 1 blocks, just look nicer when factory blocks are in place
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 7:50am
There is a place in Silver Lake MN selling some new ones for cat 2 on e-bay but they may have cat 1.
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 9:06am
Is the factory three point on the 170 and D17 IV category 1 or 2?  I thought they werre cat 2.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 9:20am
Dave, they are Cat II, sway blocks will stop the lift arms from moving sideways with either Cat I or II depending on which blocks are installed, only up and down motion.
Cat I blocks will be correct width for Cat I implements, likewise for Cat II being correct for
Cat II.
If you have Cat II blocks their will be no sideways motion on Cat II implement and Cat I implements will not hook up.  If you have Cat I blocks on the Cat I implement will have no sideways motion but the Cat II will hook up and will have sideways motion.
As an example when using the semi-mount 2000 monobeam plow, a steerable tail wheel plow, I will use the Cat II blocks to prevent side motion to keep the plow trailing straight.
HTH
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 9:57am
I have had good luck just removing one of the cat II blocks....I think that is why you see a lot of tractors with just one on. I have a set of Cat I blocks, but have never used them. Someone got a set of NOS ones from me a couple of years ago before I knew what they were worth :(
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike ( WI ) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 10:21am
Eldon,
You still have the set of Cat I sway blocks ? Let me know
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 10:54am
They store above the Cat II blocks on the tractor....some people might not realize they have a set already.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 10:59am
Here is a pic of the little guys....
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 12:31pm
Well, I just went out and checked.  Don't have the category 1 sway blocks on my D17 IV.  Must have been taken off at some point in time.  Dave
