Utility trailer jack stand
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: Utility trailer jack stand
    Posted: 05 Apr 2025 at 4:22pm
Mine drifts down while I drive. I have to crank it all the way up until it binds to keep this from happening. Do I need a new one or is there an easy fix? Thanks
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2025 at 5:13pm
Hook a bungee on the handle. I even bungee the ones on the folding jacks so they aren't hanging down when going down the road.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2025 at 5:36am
Thanks Dan! That should work, I'll check it out.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2025 at 6:33am
I've seen that a time or two in the import tongue jacks where they were not packed with enough, or a quality of grease when assembled to not wear the geartrain out. I'd bet if you disassembled that jack you'd find both the left hand acme threaded rod, and the "nut" this threaded rod bears against, worn sloppy and loose. This "nut" is what pushes the foot down and supports the tongue weight of the trailer.
Edited by Codger - 06 Apr 2025 at 6:34am
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2025 at 8:56am
Thanks codger, but I bought this trailer new. It's done this since day one. Should go back to the dealership and complain
Maybe I will? Bungee strap is pretty cheap and easy though.
This page was generated in 0.820 seconds.
