Allis Chalmers 6080 PTO
JR5653 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR5653 Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers 6080 PTO
    Posted: 31 Mar 2025 at 4:12pm
Hey guys I was wondering if anyone could point me in the right direction , I have got an Allis Chalmers 6080 that the PTO lever on the right side doesn't disengage the PTO anymore , from looking at the tractor and reading up on it on some threads here , it seems that the tractor has always been ran using just the PTO lever on the right, which from what I am seeing is terrible for the tractor , I think this because the left pull up knob in the floor was siezed in the engage position , I got it free and working properly now , I can turn the tractor off and engage and disengage the PTO fine using left hand pull up knob and works as should , I took the cable off of the big lever on right side and moved linkage by hand and i can not get the PTO to disengage in any position I put the linkage in , would this be a clutch issue with being ran so many years by just using the lever and never really disengaging the PTO ? Thanks in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2025 at 7:18pm
Probably better check crankshaft end play, because if it doesn't have the external thrust bearing update kit, that could be the problem. Even if it does have the kit, it may have a bad bearing in it. Shouldn't have more than .010" end play by my specs. As far as "stopping" the PTO, I would want it connected to something to have a load on it to get it to release.
Edited by DrAllis - 31 Mar 2025 at 7:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR5653 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2025 at 7:52pm
Thanks for the reply , i will check the play in it , it does have the external bearing and say when you are bush hogging and you want to quit cutting for any reason you can't use the lever to the right , you have to shut down tractor and use pull handle to the left of the seat to disengage pto for it to not be turning wide open ,it has always spun with no load on it
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2025 at 7:57pm
You can use the clutch lever on the right to disengage the PTO. Just don't leave it locked fully back for more than a couple of minutes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR5653 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2025 at 7:59pm
Yes sir , that is what i am trying to get back working , it does nothing anymore , you thinking it could be that bearing play if i check and it has play in it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2025 at 8:03pm
It could be, yes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR5653 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2025 at 8:05pm
Ok i will check , thank you for the help
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2025 at 11:04pm
dr.    i have always wondered why there is two levers to operate the pto on those ,  what does each one do or control ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2025 at 6:47am
Thank the Europeans for this type of PTO. Many Fiat tractors utilize this design and  6060-70-80's are a Fiat drive line. There are two clutches in the bell housing attached to the flywheel ( JD 3010-20/4010-20 similar but different). The "Traction" clutch is for the ground drive and connected to the foot clutch pedal. The "PTO" clutch is for just that, the PTO drive. Both clutches use a common pressure plate spring to engage them. It takes the foot pedal or hand lever (we call the "stage coach" handle) to release each clutch or "inch" with them. There are two sets of pressure plate fingers and two throw out bearings. Whenever you step on the clutch pedal OR pull back on the PTO clutch lever, you are forcing the crankshaft forward against the engines thrust bearing, that keeps the crank from moving forward or backwards. If you apply BOTH the pedal and PTO lever at the same time, you have doubled the pressure on the thrust bearing, which was the problem, especially in the 6080 as it has a larger diameter clutch. Anyway, you pull back on the stage coach handle, reach down to the left of the seat and pull up and grind/couple the PTO to the rear of the tractor. Then, you ease forward on the clutch handle to make the PTO work. Constant operation of the tractor with the stagecoach lever locked to the rear is the eventual death of the engine's thrust bearing. So, that's why there is a disconnect to the left of the seat. UP is engaged. DOWN is disengaged. Keep the PTO clutch handle forward as much as possible.
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2025 at 10:50am
Its possible that the clutch disc for the PTO is siezed to the intermediate plate, just like a drive clutch would sieze to the flywheel when tractors sit for a long time and the clutch pedal is not blocked down.
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2025 at 10:55am
Good point. That PTO disc is a fiber material and could do that. The traction clutch are the metallic buttons.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR5653 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2025 at 11:27am
Thanks for the info , I will dig in , the tractor has ran for years farming cotton and still is running good to this day , it isnt pretty but the only thing wrong with it is the stage coach handle , and it just quit working recently so looking to get it back working, I know for a fact that the handle was ran many hours in the back position, that is what makes me nervous about it because I have read how bad that is for them
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2025 at 5:08pm
How much effort does it take to pull the yellow ( I love the new term Stage Coach handle)  back.  I remember it should have just an inch or so of free play then is pretty darn hard to pull back the rest of the way til it locks. If there is little resistance - there may be no fingers left on the clutch for the PTO side if the bearing locked up.  Since AC never used a 2 stage clutch except the 160 6060 70 80 - the owners had a new experience with dealers who did a poor job of educating operators of the possible issues - of course there is the famous Deere 4020 PTO clutch set up....that was perfect...
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR5653 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2025 at 5:50pm
It had gotten fairly easy to pull back if I remember correctly , the pto has literly been ran off of that yellow handle ever since I can rember, tractor was bought used in the 90s and never was told the proper way to use the pto , if the tractor was running at all and the pto wasn't getting used , it was operated by the yellow handle , floor knob was never touched, so I'm sure it's probably messed up pretty good
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2025 at 7:15pm
It’s a shame all dealers did not explain the proper usage of the pto. Our dealer went over how to use it well when dad bought it new. It’s usage is also in the owners manual. But I need to remember a lot of these tractors have had multiple owners possibly and the proper operation wasn’t passed on. For hay farmers like us it works great. Get to the end of a windrow and have a ways to get to the next windrow just pull back the stage coach handle to “temporarily” disconnect the pto. When you arrive at the windrow slowly engage the stage coach handle to power the baler again. It’s called a temporary disconnect for a reason, never intended to be left back as Dr Allis stated. We replaced both clutches a few years ago, as dad grew older he often left his foot on the clutch pedal which wore the driveline clutch. Even though the pto clutch was operating fine we had Rick rebuild them both while we had the tractor split. Unfortunately he retired from rebuilding clutches and just does brakes now. He did excellent work. PTO work is mainly what our 6060 does, early model without the front support, but since we operate it correctly no sign of issues with the front bearing. The front support has a grease fitting that many look over and fail to grease leading to bearing failure in the support which provides no support to the front bearing. Check the front support to see if the bearing is still in good shape and signs of recent grease. That will tell you if proper maintenance was at least done to it.
I would agree that a split and clutch replacement would be my guess also. The big concern for me also would be the condition of the engine front bearing. I walked away from a nice 6060 when I found the stage coach pulled back. Asked the owner about how he operated it and he said didn’t use the pto much and left it in the disconnect position(pulled back) because that’s what the sticker said. In his defense the sticker does say disconnect/engage if I remember correctly. He was second owner with no owners manual.
Edited by AC720Man - 01 Apr 2025 at 7:23pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR5653 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2025 at 7:30pm
Yes sir , my grandad picked up this 6080 and a 7050 on a trade deal for one of his bigger John Deeres , so no manuals or anything came with them , I can't remember model deere he traded for the 2 allis , I guess the farmer that had it didn't show him proper usage of pto , or didnt know himself ,and he never showed dad and I am the 3rd generation using tractor so I am trying to get it back right because I really like it , it has never really given any problems , where would you normally get replacement parts ? I would like to restore it but parts seem limited , any direction to go as far as a good place for parts ? Do you have to cross reference part numbers much ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2025 at 9:40pm
Hopefully you have a good AGCO dealer near by that can help you with parts. There are a few on the site if you don’t have one close by. I regularly use the AGCO parts website, a little difficult to navigate until you get used to it. It has a complete parts list of each section of the tractor. You will have to have a factory service manual if you plan to repair the tractor yourself. It is not an easy project and the service manual is mandatory to get the job done correctly and adjusted properly. They are good tractors, some see the pto as a poor design, and in some ways it is. But as far as how it operates, it really works well for our hay operation. Use it correctly and normally you will not have issues. JMO
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR5653 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2025 at 5:53am
Yes sir , I will do that , i appreciate everyone's help
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2025 at 6:31am
You can buy the manuals from agco publications.com
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2025 at 7:31am
I've had several Fiat tractors with the same set up.As Doc said check the end play of the crankshaft if it has much you got big problems,hopefully it'll be fine and the disk is stuck to the fly wheel in which case I hook the pto to a brush hog with the PTO lever in disconnect position and that will break it loose in short order.It was amazing on a 1365 Oliver 4WD I bought how much the crankshaft had worn the block and it would still start up and run good but after about 20 m9nutes it'd lose all oil pressure.New block and crank was needed to fix it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2025 at 12:07pm
After thinking about it I'd think the throwout bearing for the PTO clutch has destroyed itself from being constantly run for years or the fingers that it runs against have all worn to pieces.Either way you'll need a new clutch assembly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR5653 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2025 at 5:51pm
I will check the end play this weekend when I get to the tractor , I guess either way I need to be fabing me up some stands to hold the front and rear and get ready to split
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2025 at 8:25pm
Be very careful when you split it. We supported the transmission, blocked the rear wheels, and rolled the front half of the tractor forward. Also be very careful when you put it back together. Take your time to line it back up, don’t force it or you will bend the clutch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR5653 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2025 at 9:39pm
Yes sir I have split a tractor before but that was at dealership I work at , 10 ton overhead crane makes things a little easier haha
