Clutch adjustment
AveryD12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Topic: Clutch adjustment
    Posted: 29 Mar 2025 at 6:00pm
Is there an adjustment for the D12 series clutch? With the clutch pedal all the way down my clutch will start to engage as soon as I begin to lift my foot. I don’t see any obvious way to lengthen the rod that would disengage the clutch. Is this another issue other than adjustment ?
Thanks
Avery
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2025 at 8:11pm
Best way to examine what's going on is to have a helper actuate the clutch, while you are under the tractor with a flash light, looking up at the clutch and clutch rod, through the inspection door.  IIRR, the adjustment is in the length of the linkage rod, you remove it from the pedal, and screw it out or in, reconnect to check the operation.  You also want to inspect the fork, TO bearing and clutch lining, looking up through the inspection hole...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2025 at 8:33pm
Thanks Dave. I wasn’t sure if there was an adjustment or not. I couldn’t imagine there not being some way to adjust it. I will take a look and see if I can spot anything outstanding. I suppose screwing out on the rod would lengthen it and therefore giving more release on the clutch disc?
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2025 at 10:52pm
you must have a gap like 1/8 inch between throw out bearing and pressure plate fingers their may be a specific muesurement in  the book but that will get it going without hurting the bearing or plate
Edited by HudCo - 29 Mar 2025 at 10:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2025 at 11:37pm
Ideally, that is pretty much how I adjust every dry foot clutch that I work on. As the clutch components wear, this dimension keeps changing and moving the pedal closer and closer to you.  Adjusted this way sees to it the throw out bearing keeps away from the clutch finger tips for many years down the road, leading to long clutch life without any adjustment seldom ever needed. As long as you can shift gears easily and start/stop the tractor easily, there is NOTHING wrong.
Edited by DrAllis - 30 Mar 2025 at 6:59am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2025 at 4:16pm
Thanks Mike and Doc.
I pulled the inspection cover and looks like the TO bearing is shot. Lots of slop in it and what appears to be fine metal shavings around the bearing. The adjustment is fully extended. It looks like a 1/4” (or more) between TO bearing and fingers on pressure plate. I’ll try to post a couple pictures.
Thanks again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2025 at 4:39pm
So, the whole story is.......it didn't used to be like this and the clutch pedal positioning has CHANGED. Normal clutch wear and tear always keep moving the clutch pedal to the rear. NOT the way yours was.
Edited by DrAllis - 30 Mar 2025 at 4:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2025 at 6:38am
You are correct. Something has changed. Not exactly sure what changed just yet, other than the TO bearing is shot. When I split the tractor what are some of the things I should be looking for other than the obvious stuff? Should I replace the clutch and pressure plate while the tractor is split? Since clutch pedal rod is fully extended is there other adjustments that can be made….like the fingers on the pressure plate?
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2025 at 8:44am
replace the presure plate,  disk , throw out bearing, piolet bearing , and have the both steps on the flywheel surfaced  front seal in the in put shaft if it has been leaking
Edited by HudCo - 31 Mar 2025 at 8:46am
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2025 at 8:59am
HudCo makes a good point
I thought my rear main engine seal was leaking, but it was the trans seal. This was on my D 15. Good luck 🤞
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2025 at 9:18am
Throwout bearing is likely shot because there wasn't any freeplay in the clutch pedal linkage, causing it to spin all the time. Or maybe it hasn't been greased in 30 years ?  Clutch disc is likely worn thin which moves the fingertips closer (too close) to the throwout bearing.
Edited by DrAllis - 31 Mar 2025 at 11:45am
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2025 at 12:37pm
The D10/12 tractors do not have a stepped flywheel. If it is a series II or III you want to replace the bushings at the front of the driveshafts. I've seen the inner PTO shaft bushing go bad and cause problems. The same goes for the Outer transmission driveshaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2025 at 6:51pm
Thanks Paul. I’ll be sure to remember that.
