1948 WC Transmission shifter removal
AZ Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AZ Gary Quote  Post ReplyReply Direct Link To This Post Topic: 1948 WC Transmission shifter removal
    Posted: 27 Mar 2025 at 6:49pm
I need to remove the shifter and build up the knob on the end. Can it be removed from the top. The detents and springs seem to be ok but the end is worn and slips out of the track.
kevin LA-CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevin LA-CA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2025 at 7:35am
Gary
I was able to get the handle out of the top with ease. I don't remember what I did with the reverse lock out, but had to remove the top to get it all back together. Not difficult, but time consuming.
Hardest part of I remember was aligning the forks with the tank still in place.
Fix the grooves and replace the pins while open. Make the wc fun to shift again.
Others may have different experience.
Kevin
Post Options Post Options   Thanks (0) Thanks(0)   Quote AZ Gary Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2025 at 9:30pm
In the process of taking the reverse shift rail out I lost both the ball and spring anybody got any extra ones I could buy?
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2025 at 10:48pm
you can get new ones from agco i replaced all of mine they didnt cost to much
Grant Forsythe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grant Forsythe Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2025 at 7:34pm
My dad rebuilds these shift towers. He can fix the end of the lever, the rack it rides in and the pin and grove it pivots on. We have extra parts to replace anything that's missing inside. You'll have to ship the complete tower to us for the repair, we do not have rebuilt units on hand to swap out. Shoot me a message if you're interested and I'll send you his number.
The Unstyled Collector
Post Options Post Options   Thanks (0) Thanks(0)   Quote AZ Gary Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2025 at 9:28pm
Thanks for the information, I really don't care about paying shipping from AZ plus paying your dad, which I'm sure would be worth it if I wanted to put that much into the tractor. I will get some parts machined locally and see what I can do. Thanks again maybe in the end I will get back with you.
Gary
This page was generated in 0.077 seconds.
