AC 670T engine rebuild
TexasWD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasWD45 Quote  Post ReplyReply Direct Link To This Post Topic: AC 670T engine rebuild
    Posted: 24 Mar 2025 at 6:47am
I have an old Gleaner L2 combine that I’m going to be rebuild the engine on.
I’m pulling the motor to rebuild it an was wanting to know the motor weight to make sure my overhead lift will pick it up. It’s an AC 670T.
TIA
'38 B with belly sickle,'52 WD,'54 WD45,'39 WC,'47 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2025 at 7:25am
Not a ton. I'm thinking around 1500 lbs for just the bare engine not the radiator and frame.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2025 at 2:37pm
Per Allis-Chalmers FE-724 691 (January 1969) Model 3500 Turbocharged 192 hp diesel engine brochure;
net weight basic engine: 1310 lbs (dry~no fluids?)
So if engine contains fluids and you'd like to calculate to include fluid weights; then below are fluid capacities listed in brochure:
crankcase capacity: 15 qts   (weight? 3.75gallon @ 8lbs/gal ~ 30lbs)
cooling system capacity(engine only): 14 qts   (weight? 3.5 gallon @ 9.6lbs/gal ~ 33.6 lbs)
Edited by AC7060IL - 24 Mar 2025 at 2:51pm
