2-71 crank wick removal
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Topic: 2-71 crank wick removal
    Posted: 23 Mar 2025 at 7:56pm
Anyone know when removing the wick on the rear of the crankshaft of a Detroit 2-71 that lubricated the clutch pilot bearing, is it a 1/8 or 1/4” pipe thread or something else? Freshening up the clutch and want to remove it replacing the open pilot bearing with a sealed bearing. Loader is 150 miles away to check. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2025 at 6:37pm
It's NPT - or plumbing thread -
Then replace pilot bearing with a sealed bearing (pre lubed)
Did that on mine back in 1972 when I bought my machine
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2025 at 6:33pm
Thanks! Headed this weekend to put it all together.
