PLUMBING FRONT END LOADER ON 185
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Topic: PLUMBING FRONT END LOADER ON 185
    Posted: 23 Mar 2025 at 6:59pm
WONDERING IF THERE WOULD A PROBLEM PUTTING A TEE IN THE PRESSURE AND RETURN LINE BEFORE THE REMOTE / 3 PT VALVE  SO THAT I CAN PUT A JOY STICK VALVE FOR THE LOADER. I LOCATED THE 2 LINES AND WANTED TO GET SOME INPUT BEFORE I CUT THE LINES
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2025 at 11:47am
Won't work that way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2025 at 8:26pm
i think the FACTORY valve dumps back to sump until you move the lever to direct oil to the cylindner and BUILD UP PRESSURE.... So the line only has 100 psi (??) when the remote is not engaged... ???
if you ENGAGE the remote and lock in that position, then you could use your loader valve-- and IT would recycle the oil back to SUMP when the loader was not being used. ???
Is that right DR ??
Edited by steve(ill) - 26 Mar 2025 at 8:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2025 at 9:08pm
He needs a open-center joystick valve that has the "power beyond" feature. Send the hydraulic oil from the pump to it FIRST and then from the joystick valve onto the tractor valve. Everything will then work as it should. A tee won't work at all.
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2025 at 9:49pm
Get a hold of Tracy martin here on the forum he add a joy stick to a 170 (I believe ) and he send the drawing for to me to post it on here but now I can't find the post or the drawing that I though I had save. HTH
Edited by Kenny L. - 26 Mar 2025 at 9:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2025 at 10:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2025 at 10:06pm
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2025 at 8:14am
I just put a 3pt log splitter with a closed center valvue on the back of my 185 to use.
I'll have to tie up the hydraulic lever on the tractor to supply oil to the log splitter all the time. Will this cause any harm to the pump have pressure to the splitter constantly?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2025 at 8:28am
A closed-center valve on a 185 ?? Bad idea. You will have to tie a remote lever into engagement to have oil available for the closed-center valve, yes. This forces the hydraulic systems relief valve to open and squeal, creating excessive heat and placing the hydraulic pump under a constant 2200 psi load, which it CANNOT withstand for long. Nothing good is going to come from this. If the hydraulic pump doesn't fail first, the nose of the camshaft may well break off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2025 at 8:30am
the splitter should have an OPEN CENTER valve to recirc oil back to the sump.. YOu dont want MAX PRESSURE on the pump and line when the cylinder is not being stroked..
Dave... some valves can be MODIFIED by removing a plug so that the valve becomes OPEN CENTER... look at the manufacturer spec for your valve.
Edited by steve(ill) - 27 Mar 2025 at 8:32am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2025 at 12:54pm
Thanks guys, it has a closed center valve becasue it's usually on a JD 3020 with closed center hydraulics. I hooked it up and wanted to try it on my 185 but then was thinking and afraid it might be a bad idea
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2025 at 6:35am
FOund a ocnversion pluf I can buy to change from Closed to open Center. Thanks for the idea. I wouldn't have thgouht of that.
It's a prince valve. I'll put in a recommendation for Prince. Made in the USA. I called and got a receptionist form the US. Left a VM with the guy I needed and didn't expect a call back. he called back within 10 minutes. I emailed him pictures of my 18 year old valve and in about an hour he found and sent the part number I needed for the conversion plug.
scott in tenn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott in tenn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2025 at 11:40am
Ran the set up as Dr Allis described for year without any issues. 2 elbows and open center valve and your in business.
This page was generated in 0.044 seconds.
