HD11EP torque converter install
AC Mel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Mel Quote  Post ReplyReply Direct Link To This Post Topic: HD11EP torque converter install
    Posted: 22 Mar 2025 at 12:18pm
Ok...you tube link to HD11EP transmission and torque converter installation progress.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2025 at 4:24pm
As you mention in the video the replacement hoses you made up; mine are aged pretty well also and I ordered a spool of R16-8 hose and braided sleeving to address the same. Mine has some rub spots where the retainers didn't quite protect them. Also 30 fittings to have a bit of stock on hand for other things as they're common usage.
Had to go to Turkey for clutch parts? Both frictions, and steels? I was yapping with a gent over in Cleveland and he tells me he can still make them if the order is large enough because the oven to bake them is expensive to run. I asked and a single tractor order is enough but it would need to wait for another job to go with. I was asking about steering clutches but transmission are the same in that arena.
The help you guys gave me, work I had performed, along with my own labor has been, and is working well.
Thanks,
Edited by Codger - 23 Mar 2025 at 7:33am
That's All Folks!
