Chopper question
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Topic: Chopper question
    Posted: 18 Mar 2025 at 8:53pm
What is the recommended hp for the 720 and 780 choppers?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2025 at 4:36am
70 to 95 HP, per Swinford's book...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2025 at 6:34am
On page 5 of my official One-Eighty advertising literature book, dated 1969, I have a pic of a 780 chopper chopping hay, being pulled by a One-Eighty diesel. I think you could pull it with a WD-45, but it would be slow going and the more full you kept the chopping knives the better it would perform.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2025 at 1:46pm
My Dad used a WD45 (biggest tractor he had) on his new 780 with a (6' ?) direct cut and one row corn head from the time he bought the chopper new (~1969) until he bought his One-Eighty new.
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2025 at 6:18pm
There is no way to run my 780 on such a small tractor. It has 1000 pto
Tenn allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tenn allis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2025 at 8:14am
A 200 with dual shaft would work great we pulled a 1 row for several years with a 200
A 185 with dual shaft will get you by but if your trailing a good sized wagon behind it can be a load going uphill or trudging thru wet ground
ac-mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac-mike Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2025 at 11:17am
Had the pleasure of running a 780 for years. I have used many choppers and believe the AC 780 was one of the easiest to pull. Its downfall was the head attachments, they only worked well in ideal conditions. I first pulled it with an AC 180, it was a good match. The available HP was about the most the chopper could use on a level run. Around here there are not many level runs! We pulled 14' boxes with third beater extensions and roofs on top, when these were getting full it was taking a lot of HP to pull all this on soft ground up hill and run the chopper also. We than upgraded to a AC 200, we soon learned this was all the power the chopper could handle, the feed rolls could not get any wider and would occasionally jam. This chopper gave us problems because it was a cut and throw instead of a cut and blow. Never had any problems with corn but alfalfa was something else. It would not throw it past the beaters on the wagon. I studied the operators manual and made the adjustments to the pan that directed the flow and could get it into the wagon a lot better. I could tell more stories about this but I will stop here. Still love AC!!!!
D-12III, 200D, 170G, HD-3, D19D 3pt, D17D High Crop, WD45G p/s, D15IID, D15IIG, D15G IND, 655, (3)WD45D p/s, 700, 816
