Front wheel bearing seal
AveryD12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Topic: Front wheel bearing seal
    Posted: 18 Mar 2025 at 12:55pm
Repacking the front wheel bearings on the D12 series 3. Decided to replace the seals. I never saw a seal like this and I am unsure the proper way to install it. I assume that I should drive it on the spindle and the hub turns against the felt. I’ll try to post a few pictures.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2025 at 1:19pm
The Allis P/N for that style Seal is 207365.
From the Allis Parts Catalog it appears Allis used that Style Seal
on Ser. I and Ser. III.
From the picture it appears that the Seal installs to the bottom of the front
Spindle with the Outer Diameter Seal Portion facing outboard towards the Hub.
It appears you would have to press the Seal on to the Spindle.
The Seal would remain Stationary and the Hub would turn.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2025 at 1:28pm
Thanks. I will need to remove the spindle and carry it to a shop that has a press to get it installed.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2025 at 1:39pm
Avery
I don't think you need to go to that much work.
Do you have a set of 3/4" Drive Sockets?
Choose a Socket large enough to just fit on the inside below the Seal Material.
Add the long 3/4 Drive Extension so that you can keep the Seal square to the Spindle.
If you don't have a Set of 3/4 Drive, a piece of pipe a foot or so long would work.
Gary
Looking closer at the Picture, that Seal may face inboard.
Perhaps do a dry run by assembling the Hub and Bearings to the Spindle to be sure.
Edited by Gary - 18 Mar 2025 at 1:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2025 at 1:42pm
I've made a tool which just fits over the spindle and is the proper length to use the nut to draw those seals in place. Be sure to oil the felt real good.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2025 at 1:47pm
Paul
Perhaps you could verify for Avery which way the Seal faces.
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2025 at 1:49pm
The side with the 1177 mark goes on first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2025 at 2:04pm
Thanks for the help
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2025 at 3:50pm
Paul
Do you have picture of the tool you fabricated for installing this seal? I would be very grateful if you can share it with me. I think I understand the concept but a picture would be most helpful.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2025 at 7:06pm
It's just a piece of pipe that I bored a length inside to fit the spindle and a thick washer under the spindle nut. I've found no other way to get them started straight without bending them now that all of them are made in China or someplace else now. The old NOS ones would tap on easily every time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2025 at 8:15pm
Ok. Thanks. I believe I can build something like that. I tried a 1-1/2” pipe collar/sleeve and it is slightly smaller than the OD of the seal. I can probably reduce that to a smaller diameter pipe that will be slightly larger than the spindle diameter and cut to length. Thanks again for all your help. I did notice the new seal is thicker in area that goes on the spindle. I suppose the old one is worn from years of use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2025 at 6:29am
You want the ID of the pipe to just fit onto the spindle.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2025 at 10:04am
Just looked this Seal up on Amazon. $350 CAN
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2025 at 12:15pm
Paul
Thanks, I will see what I can come up with.
Gary
$350….that’s unreal. I gave $20 for this one.
This page was generated in 0.434 seconds.
