Magneto question
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Topic: Magneto question
    Posted: 09 Nov 2010 at 5:03pm
Will a Fairbanks Morse FM 4B magneto work on a 39B.
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2010 at 5:39pm
I believe you mean FMJ4B. Yes, they were the stock magneto that came on the B's. The FMX replaced the FMJ in the 50's. I was told that the FMX never came from the factory, but was instead a dealer shelf part swap if the FMJ went bad.
tododell48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tododell48 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2010 at 6:21pm
Yes the fmj4b will deinitely work.
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2010 at 7:41pm
If it is just an FM 4B and not an FMJ 4B then I'm not sure if it will work or not - they are two different models. I think I've seen the FM 4B mags on WC's before, but I don't know about B's. Hopefully someone else with more experience will chime in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2010 at 8:34pm
I've looked again fellows and there isn't any J or X just FM 4B.  Tim
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2010 at 8:54pm
Check the lag angle set on the FM 4B as opposed to the FMJ 4B. I believe, if my memory serves me right, (which it doesn't sometimes) that you need  a 30 degree lag angle for the spark advance to make the 125 engine run at it's best.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2010 at 9:15pm
The reason for all the question is........ this magneto was on the tractor when I bought it.  Have not had the engine run, but the coil appears to be bad in the mag.  If it isn't correct for the B engine I'll look for another rather than have this one repaired.     Thanks Tim
