8050 blower motor
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Topic: 8050 blower motor
    Posted: 17 Mar 2025 at 2:51pm
Is there a way to check the resistor thats next to the blower? Or does it work or not?
I keep blowing fuses but the fan motor turns freely.
Thanks Randy
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2025 at 3:36pm
Id take the wires from the switch to the resistor off turn on the switch to make sure its not the wires between. If it doesnt blow the fuse id put those back on and take the wires from the resistor to the motor off. If the fuse doesnt blow then its the motor. If its the motor id get a high eficiency blower assembly from ap air. They are super quiet and dont use a resistor
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2025 at 6:35am
Will try that.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2025 at 6:58am
Well, i found the problem, bare wire on the compressor. Every time i would turn the thermostat to cold the fuse would blow. So it was a easy fix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2025 at 3:55pm
Fantastic. Thanks for letting us know how it turned out
1984 80780
1957 D14
616 tractor
