37 wc budget build puller |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4063 |
Topic: 37 wc budget build pullerPosted: 16 Mar 2025 at 4:11pm |
![]() ![]() ![]() this was april two years ago
Edited by HudCo - 16 Mar 2025 at 8:33pm |
HudCo
Posted: 16 Mar 2025 at 4:23pm |
![]() working over new manifold for new d19 zenith carb
DrAllis
Posted: 16 Mar 2025 at 4:45pm |
The D-19 carbs I have used in the past (Marvel-Schebler, not Zenith) I drilled out the seat of the needle and seat. This is because gravity fuel flow from the tank sometimes couldn't keep up when running 2500 RPM on a 300 ft track. So, be prepared if you run fine up until the end and it seems like it might be running out of gas
HudCo
Posted: 16 Mar 2025 at 5:31pm |
i believe thats the very first brand new tractor carb i have had , its big old girl it clears the block by 1/8 will start updating pictures
Phil48ACWC
Posted: 17 Mar 2025 at 8:06am |
I have a WD-45 Crank I would sell. $300 plus shipping.
HudCo
Posted: 17 Mar 2025 at 8:30am |
have had a new 45 crank in the box for about 4years , i am useing a d17 series 4 engine that i got from the scrapper after the claw destroyed the rest of the tractor
HudCo
Posted: 17 Mar 2025 at 8:36am |
HudCo
Posted: 17 Mar 2025 at 8:51am |
.060 above deck head gasket composite is .065 still waiting on the head before we work on the pistons
HudCo
Posted: 17 Mar 2025 at 9:02am |
![]() ![]() wasted money having the fly wheel of the wc turned for the ring gear it weighed 65 the wd wheel weighed 59.8 center in the wc one is solid i thought it would end up a few pounds heavyer but it came out 59.8 and the machine shop messed it up and had to weld it up and turn it agan . my new little buddy star helping
DrAllis
Posted: 17 Mar 2025 at 12:17pm |
Be sure to mark the flywheel for 15-20-25 degrees. The Fire mark is 30 degrees BTDC. 15 is half-way between fire and TDC. You'll figgure it out.
HudCo
Posted: 18 Mar 2025 at 8:50pm |
HudCo
Posted: 18 Mar 2025 at 10:43pm |
hitch and wheellie bars almost doneu
ploads/8753/IMG_1028.jpg
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5271 |
Posted: 19 Mar 2025 at 6:38am |
Just imagine where your pull point is going to be if by chance the pin at the front of the drawbar were to shear off. When I was a safety inspector for different clubs I discouraged drawbars with that sort of height adjustment. A cradle built around the drawbar with push bolts up and down that will allow the drawbar to slide cleanly our without changing the pull point to a higher position is much safer.
HudCo
Posted: 19 Mar 2025 at 8:33am |
not much to biuld to on that tractor
HudCo
Posted: 19 Mar 2025 at 8:45am |
guess thats what the wheelie bars are for. this is the first puller ive biult and probley the first dedicated puller in my area their isnt much for hitches out on the inernet for hitch or wheelie bars for the wc if it dont work i will do somthing differant . i should be the big fish in a little pond for a while hoping to spark a little more interest around here without spending a zillion
PaulB
Posted: 19 Mar 2025 at 7:21pm |
When you find out it is an issue, it will be too late. Just build a support attached the same as the OEM. Then make a provision with push bolts up and down.
I've seen numerous hitches break in the past 50+ years.
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5180 |
Posted: 20 Mar 2025 at 5:42am |
I always thought I would like to build a set of wheelie bars that could be removed or raised by just pulling one pin on each side, similar to the way a receiver hitch on a pickup truck. The wheelie bars can be a real problem when loading/unloading. Front end goes up and the wheelie bars hit the ground.
Edited by WF owner - 20 Mar 2025 at 5:43am |
HudCo
Posted: 20 Mar 2025 at 10:18am |
the framing square and the tube clamped to it is right at 5 inches beyond the radius of the tire and 10 inch high so if i put my pad on it that will be in the rules i should be able to pull a pin and slide them up and be flush with tires and not be in the way for loading. i am hoping the angle is enought that if you hit the wheelie bars they are skids and not rippers
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 21 Mar 2025 at 10:00am |
Hudco, we havnt spoken for awhile. Our conversations regarding flywheels. yes the 45 flywheel does not have the undercut on the clutch side, but it does have less material on the crankshaft side. Have not been able to weigh them but the difference might be closer than we think, and reading you post above confirms that.
Edited by CAL(KS) - 21 Mar 2025 at 10:02am |
Dad- WD, D17D, D19D, RT100A, 7020, 7080,7580, 2-8550's, 2-S77, HD15 |
HudCo
Posted: 22 Mar 2025 at 6:24pm |
wc and wd flywheel but is a wd 45 flywheel any differant ? i dont have one to weight i was supprised that the d17 wheel is lighter with the ring gear, i think it was 58 lb. by the way nice videos
Edited by HudCo - 22 Mar 2025 at 6:25pm |
Kip-Utah
Joined: 14 Sep 2009 Location: Southern Utah Points: 921 |
Posted: 24 Mar 2025 at 9:14am |
We use two WC flywheels as weights on one of our pullers. One is for a crank starter and the other one has a ring gear. They both weigh 65 pounds.
HudCo
Posted: 24 Mar 2025 at 9:20pm |
kip i want to come down south this summer and maybe get a lesson or two at least have a little fun
Kip-Utah
Posted: 24 Mar 2025 at 11:48pm |
We’ll have our first pull at the Washington County Fair in Hurricane on April 19 at 10:00. The Cotton Days pull will be a week later on April 26 in Washington, Utah. Then we won’t have another pull until Labor Day weekend at the Iron County Fair in Parowan. Then our best event of the year will be our two-day pull in Cedar City on October 24-25. This is held as part of the Cedar Livestock & Heritage Festival. The pull on Saturday the 25th is unlike anything you can experience anywhere else. We have a draft horse pull & tractor pull on two side-by-side tracks in the same arena at the same time!!! We’d love to have you come down. Kip (435) 592-4045
HudCo
Posted: 29 Mar 2025 at 12:11pm |
kip thanks for the chat on the phone the other day
HudCo
Posted: 29 Mar 2025 at 12:26pm |
![]() ![]() got some weights ready but i need to find a oil filter base base for the d 17 series four engine lube system and also a usable distributer the inside of mine was rusted beyond rebiuling . i have points condensors and tune up stuff also have a pertronix that i will use , so far i havent found a filter base and distributor close around me
Kip-Utah
Posted: 31 Mar 2025 at 4:14pm |
Mike, I enjoyed our visit as well. Gleaner E, 170, 175 are all candidates for the parts you're looking for. Kip
HudCo
Posted: 17 May 2025 at 6:15pm |
my machine shop finally got the head done i dont remeber the valve sizes but they are about all that will fit in the long reach plug head the shop laughed at my lift on the 175 cam and i didnt one rocker that needed ground , so i raided my private stash and bought a set of murpheys 1.85 rockers, to they are going to mill .070 off the tops of the piston thats will put me .011 below the deck head gasket is .065 thats going to be real close for the valves . at .070 they figered right at 12 to 1. they are just going to cut a radius where the valve are not just keep cutting the top off. how much will i need to cut for pockets for valve clearance ? no offset cam keys
HudCo
Posted: 20 Jun 2025 at 8:14pm |
where should i place wieght brackets i have my battery underneath in front of the rear end i was going to build a bracket to fit three of those 75 lbs ih weights about a foot in front of the rear axle and some brackets off of the the square bar under the axle so that would put the weights just behind the center line of the rear end i will biuld a bracket for the front but i am sure i need to start in the back. where should i put put them for starters ?
HudCo
Posted: 07 Jul 2025 at 3:36pm |
HudCo
Posted: 07 Jul 2025 at 3:42pm |
believe they took .100 off the top with the high ratio rockers the stock push rods are a litttle short they woud have worked but kind of made a bad angle, smith bros. are sending 3/16 longer ones
