Timing light
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Topic: Timing light
    Posted: 16 Mar 2025 at 7:15am
I need to pick up a timimg light. Needs to work on 6 volt systems. Any preferences? Don't mind buying a used one off ebay if the older ones are superior
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2025 at 7:31am
Not sure about the 6 volt but I bought one at harbor freight and it wasn't very bright. Hard to see outside. Good luck
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2025 at 7:56am
You can use a 12V car battery to power the timing light and the inductive pickup on the #1 plug wire of the vehicle to trigger it.
I have an older "Sun" timing light that works on 6VDC just fine. Not looking to sell it but it has been a good one as a recommendation.
That's All Folks!
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2025 at 9:47am
This is what I have had to do as well. I bought a newer Innova 12V timing light and just drag a separate 12V battery over next to the 6V tractor I'm working on to power the light. I'm honestly not sure if you can buy anything new that would work with 6V, so you may have no choice but to go the eBay route for an older used one.
Edited by wjohn - 16 Mar 2025 at 10:09pm
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2025 at 8:06pm
This is what I have had to do as well. I bought a newer Innova 12V timing light and just drag separate 12V battery over next to the 6V tractor I'm working on to power the light. I'm honestly not sure if you can buy anything new that would work with 6V, so you may have no choice but to go the eBay route for an older used one.
heck yeah  I used the lawn tractor for the 12V power source since it was easy to push around.  Wink
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2025 at 10:27am
You don't even need a very good 12 volt battery to power a timing light.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2025 at 11:29am
I have one of those little 12v batteries out of a emergency door light I keep for such things
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2025 at 9:08am
Just reminded me, I have a pm to answer on batteries! Memory like a sieve...
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2025 at 1:47pm
At one time I had a timing light powered by 4 D-cell batteries. It worked great on anything, even lawnmowers to check for spark. I don't know where it disappeared to, although I have a suspicion.  Probably like everything else logical and practical, they don't make them anymore.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2025 at 3:15pm
I have 1980s Sears Craftsman timing light. I’ve owned since new. And yes it’s still working great.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2025 at 3:39pm
bought an old fox river one from a patient for a handful of floss and a new toothbrush
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2025 at 12:53pm
Are you sure you didn't overpay him??? Lol!!!  Smile  Smile  Keep in mind the flos and toothbrush came free from the salesperson.
Edited by Ed (Ont) - 26 Mar 2025 at 7:57pm
This page was generated in 0.172 seconds.
