I need some help or advice
C15TA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C15TA Quote  Post ReplyReply Direct Link To This Post Topic: I need some help or advice
    Posted: 12 Mar 2025 at 9:06pm
I have a gas 170 and a diesel 170 that both have issues. The gas smokes, needs a clutch and the hydraulic pump needs another rebuild The diesel I have put about one hour on it since purchasing it three years ago. It has been a constant source of pain. Last week I lost a 25X32 building because of the snow load and need to get a tractor heavy enough to clean up the mess. I have spotted a Case IH 585 with a 2200 loader  (3900 hrs) and a Massey 255 with a Buhler loader. I don’t know much about either of these other than the Case having short clutch life. I am asking for a little input, advice or insider knowledge on either of these tractors… Maybe I should try to resurrect the gas 170 and limp through with it. Any thoughts are welcome…
Thanks,   Barry
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2025 at 9:15pm
The 170 needs an overhaul if it smokes blue. HOWEVER, just put in four AC Delco 46 XL hot spark plugs and add a quart of 30 wt oil whenever it gets down to the add mark. $100 will buy a LOT of oil and the tractor will still run fine. New foot clutch and what's the hydraulic pump doing ?? Bet it's not the pump. Easy decision.
Edited by DrAllis - 12 Mar 2025 at 10:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote C15TA Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2025 at 7:10am
Thanks for the reply Doc. The oil I can live with. The hydraulic pump grenaded shortly after I bought it.  It also snapped the previously welded pinion that drives it. A local ex dealer supplied a new pump and used pinion and it worked good but was very noisey. I paid for a new pump from Allis but I am pretty sure it was a China unit and it was very noisey. After a couple of years I had some stiff steering so I pulled the pump and replaced the worn and scored parts. After a couple of years it got stiff again and then cracked the center section. A buddy who is a millwright and did all kinds of pump and hydraulic work for General Motors took it into the factory and went over it with all new Allis parts. Now the steering is acting the same again. You have to turn the wheel very slow. The 500 loader has good pressure and would lift the Titanic. I love this tractor and that is why I jumped at the 170 diesel which has been a disappointment. I had the gas booked for an overhaul and clutch but after nine months of being put on the back burner I gave up.
Barry
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2025 at 2:33pm
Barry
I live in Port Hope, what is wrong with the 170 diesel?  What kind of hydraulic fluid are you using in the gas 170?  Very odd that all your pumps are going bad - they are not usually a problem on these tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2025 at 3:04pm
I'd sure be looking at the screen inside the hydraulic sump. It is very fine, and if dirty, could be restricting oil flow to the pump.  I can count on one hand how many D-17 IV and One-Seventy hydraulic pumps I've ever gone thru.
Post Options Post Options   Thanks (0) Thanks(0)   Quote C15TA Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2025 at 8:38pm
Thanks for the replies guys. DSeries it’s a small world. I live north of the Big Apple and pass Port Hope twice daily on my way to and from work in Whitby so we are neighbours. I can’t remember the brand but I use fluid that I bought from Trewins the old Allis dealer in Blackstock.
Dr. I must confess I haven’t checked the screen in the sump for years. When the pump blew the first time Earl at Trewins cleaned the screen out and it had a rip in it so he brazed it up. It was NLA and he couldn’t find a used one. He told me then that it was important and it was one of the first things that I did when I bought the diesel. The first thing I noticed on the diesel was how much quieter the pump was.
Thanks again..    Barry
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2025 at 9:40am
Earle really is a legend for Allis Chalmers knowledge in the area.  I have dealt with him for years - lots of good stories too!
Regarding your hydraulic problems, there must be some contamination in the system that keeps destroying your pumps.  I would drain the entire torque tube and flush it with diesel.  Debris could also be in the valve body and loader cylinders as well.
What is wrong with your 170 diesel?  I have a line on a 175 diesel that I might be getting for parts.  170 and 175 share a lot of parts, so I might be able to help you out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote C15TA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2025 at 9:24pm
The 170 gas has been sitting behind the barn covered with a tarp for the last three years. I guess this summer I will have to try and resurrect it. The diesel is in the barn  waiting for a hydraulic repair. I used it for a few minutes after I finally  got the fuel system sorted and the left ram for the three point started to puke fluid. I have soaked the hair pin and the pin with penetrant for months but it is rusted solid. I think the next step is to dig out the hot wrench. I had the same problem with the gas 170 shortly after I got it and I managed to drill the pin with progressively larger drill bits and finally got it. It was quite a job and I was 25 years younger. I think I can get in there with the torch and shave the end of the pin off enough to remove it. Since it has been only running in the barn the engine has developed a noise that  wasn’t there before. I am not familiar enough with diesels to identify it. DSeries4 thanks for your reply.
Barry
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2025 at 9:47pm
I reseal those cylinder in chassis. Leave the barrel on the tractor and pull out the rod.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2025 at 9:37am
Not sure of all the details here - but if you 'grenaded' the pump and then the drive, it is usually due to stuck or plugged relief valve in the valve block for the remotes and three pt hitch..
Post Options Post Options   Thanks (0) Thanks(0)   Quote C15TA Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2025 at 8:42pm
Dr, I had read somewhere about rebuilding it on the tractor but discounted it due to space limitations. The rams on mine are the later model large ones. I just read the IT manual and it says remove the circlips but doesn’t say how to access them. I have been looking online this evening for a proper Allis manual to download but haven’t found one.
tbran I have had the relief valve out numerous times and it seemed okay to an inexperienced eye. I put a pressure switch in one of the outlets at the back to watch the pressure but maybe I should move it to the dash where it is always visible.
Thanks guys…Barry
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2025 at 8:49pm
I know you have the large cylinder rods. I didn't say "I rebuild them in chassis" and lie about it. That's the way I do them if I can't get the barrel clip or pin removed.
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2025 at 7:14am
I don't think he was suggesting you were dishonest about or ignorant of the later cylinder rods Doc, just think he was looking at it & thought it'd be more of a pain working in-situ than removing the pin.
I've been here long enough to realize you've forgotten more AC facts than most of us will ever learn, but I've also been more active over my first 6 months here than Barry has over the last 6 years so I've read a lot more of your posts to know this Wink  Looking at a couple of photos I can see it looks tight for access but can't see anything jumping out that'd make me feel it wasn't possible, just that it'd be a PITA working down there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote C15TA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2025 at 11:30am
Thanks ekjdm14 for coming to my defence. Dr. I am sorry if I offended you with my reply. My intention was to get some guidance in how to access the circlip not to suggest it was impossible to do and that you were lying. I am on this site reading almost every day and like others realize you know what you are talking about. I also understand the limitations of this semi old (78) body. I question whether it will bend down in there and more importantly can I extract myself. Knee and shoulder operations slow you down. I included the info on the large rams because on the gas 170 I changed the smaller leaking ones to the larger model because Earl had two fresh ones and I only had to pay for the kits.
Barry
