D17 steering leak
71cgrave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 71cgrave Quote  Post ReplyReply Direct Link To This Post Topic: D17 steering leak
    Posted: 11 Mar 2025 at 10:03pm
Have a 1960 d17, it started leaking ps oil from underneath the radiator on top of tank. Between the front mount pump and the add on loader we can't see where from, any ideas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2025 at 10:18pm
If it happened all at once so to speak, I'd say it is leaking on the right side behind the grille shell. There are four tapered head allen bolts that sometimes loosen up with age.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 71cgrave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2025 at 7:57pm
Not leaking there. Had it parked downhill today and could watch it run across to top of oil tank on the left side looking at the front
Post Options Post Options   Thanks (0) Thanks(0)   Quote 71cgrave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2025 at 7:59pm
Have to take the loader lose to get the side panel off
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2025 at 9:10pm
Best way to see it is to remove the shroud, maybe even the radiator if you still can’t see it. The fitting that the sump line attaches to is aluminum it may be cracked and leaking. NLA so I had a hydraulic shop make me a new fitting and hose connection. Works great.
Edited by AC720Man - 14 Mar 2025 at 9:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2025 at 9:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2025 at 10:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2025 at 10:18pm
A year and a half later and the new fitting still works great.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2025 at 8:52am
You did a great job on that 17!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2025 at 6:41pm
Thanks Mike. Almost a year worth of work to it and a lot of new parts. I do enjoy that tractor. I would be surprised if his leak isn’t with the original fitting.
Edited by AC720Man - 15 Mar 2025 at 6:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2025 at 8:21pm
71cgrave have you found the leak yet?
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2025 at 7:20am
That really is a lovely job on the D17, I'd be scared to hurt the paint though if I had a machine that nice!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 71cgrave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2025 at 9:36am
Been busy calfing, getting back into it today
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2025 at 2:03pm
I like em to look nice and be reliable when I put em to work. That first scratch always hurts but I buy them, repair them, verify no more issues, and then I paint them. Labor of love but I don’t like the new tractors and their technology. I can fix old school, not this high tech stuff. I’m working on a 1959 D14 presently I purchased a few months ago, baby brother to the D17 in the above pic. Hope to have it finished before hay season starts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 71cgrave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2025 at 2:59pm
Not from either line, coming from under radiator, have to take loader of to get to shroud bolts 2 pull radiator
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2025 at 3:20pm
Could be the shaft coming out the bottom of the steering box.  Might need to replace its bearing.  Did it on my D17 several years ago.  Also check where the steering shaft goes in to the steering box on the left side.  Those seals usually go bad after decades of use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2025 at 10:45pm
Mine was leaking at the steering orbiter and it was running down on the tires(narrow front). I went completely through it replacing all seals. He says it running fluid on top of the front support under the radiator, seams like that would be either a cracked suction fitting, the line, or a crack in the front support on top which I highly doubt. Or from the front mounted pump that drives the loader?
Edited by AC720Man - 10 Apr 2025 at 10:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2025 at 8:50am
If it truly is getting oil on top of the front support, I'd be thinking it's coming from the oil fill breather and it's because the oil level is overfull or it's getting AIR in it making it foamy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 71cgrave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2025 at 5:00pm
Nope, can see the fill, under radiator
