Ford Guys...Remote Start |
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18967 |
Topic: Ford Guys...Remote StartPosted: 10 Mar 2025 at 4:15pm |
Hi Guys, I've got a 2015 F150 and the remote start just quit working. I started it at home and it worked. Went to visit my sister and when I was going to leave it wouldn''t work. I pushed the buttons and the lights blinked and the horn sounded. What should I be looking at to fix it? Thanks
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90821 |
Posted: 10 Mar 2025 at 4:27pm |
Here is the sequence of event in order.. Sometimes if i delay too long between the "push this button, then that button" , or 2019 FLEX does not start......the HORN is not part of the sequence.. Horn is a signal that means NO START.. --------------------- Here's a more detailed explanation:
Edited by steve(ill) - 10 Mar 2025 at 4:29pm |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25255 |
Posted: 10 Mar 2025 at 4:28pm |
Check one of the 3 fuse panels for a blown fuse. Hopefully you HAVE the pristine manual in the 'glove' box. They should show where the fuses are and what they power. Hopefullly one is labelled 'remote start'. Since the horn beeps,lights flash is the signal to the 'starter system' that isn't making the trip. The 'control box' should be OK.....
steve(ill)
Posted: 10 Mar 2025 at 4:31pm |
also try standing 20 ft from the truck instead of in the house.. see if that works...
sparky
Joined: 13 May 2011 Location: So. Indiana Points: 1834 |
Posted: 10 Mar 2025 at 4:49pm |
Maybe check the battery in the key fob too.
Steve in MI
Joined: 09 Jan 2019 Location: Hesperia Mi. Points: 28 |
Posted: 10 Mar 2025 at 5:24pm |
if you have a check engine light on the remote start won't work , at least on my dodge it wont
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5911 |
Posted: 10 Mar 2025 at 8:08pm |
Remember - Ted said it was a 2015 F-150 Teds Truck has probably heard all the Tariff News going around. It realizes that when Canada stops shipping that 50% of Canadian Manufactured Truck Parts and that 100% of rolls of Aluminum to Stamp out all that Ford Pick-up Sheet Metal, Ford Manufacturing Trucks will cease. Those few remaining F-150's, one's like Ted's, will become Collector Classics. AND MORE SOONER THAN LATER How does that Classic Song go? Oh Ya "LEAN ON ME" G |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55282 |
Posted: 11 Mar 2025 at 4:51am |
You forgot check the antifreeze, gaREE! Politics belongs downstairs, and your hatred is showing again... ![]() And did I hear a request? ![]() |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35679 |
Posted: 11 Mar 2025 at 5:12am |
Can attest to this one. 2017 Exploder, fob would Unlock doors or Lock them, would NOT open rear hatch or start car, was battery getting weak.
steve(ill)
Posted: 11 Mar 2025 at 8:29am |
2015 is 10 years old........... battery change is a GOOD idea, even if not the problem.
Gary
Posted: 11 Mar 2025 at 9:43am |
Ya I guess you're right Dave, but it just seemed so fitting! LOL Funny nobody asked Ted if he still had the 2nd Remote that he could give it a try. G |
Ted J
Posted: 13 Mar 2025 at 6:10am |
Well guys, I got er fixed!! The batteries in the fob were good and as per Gary, I tried the 2nd fob and that too was no go. So,,,,,,,,,,checking the fuses etal,,,,,,,,, I figured that if the lights flashed and the horn honked, that it wasn't the batteries in the fob or the 12v. Did some checking on Youtube and there was some stuff about the pressure switch under the hood. I went to look for that and there wasn't one!! BUT,,,,,,slamming the hood shut,,,,it WORKED!! Ergo, there has to be a switch there somewhere, but I couldn't find one. At least there is nothing visible.... So,,,,,,,,THANKS guys!! That did it.
DMiller
Posted: 13 Mar 2025 at 6:12am |
Also inspect for Rodent Damage to electrical cables, Eng Coolant Temp Ga loss on my SD Ford was a Rat Bite/Chew mark.
steve(ill)
Posted: 13 Mar 2025 at 8:33am |
switch may be under the hood LATCH at the front.. Look for a harness with a couple wires... You should get an LIGHT/ ALARM if it was not working........... but glad it is fixed !
Gary
Posted: 13 Mar 2025 at 9:24am |
Steve If Ted hadn't got the Remote Start working, is that something that your recommended MotoPower OBDII Diagnostics Tool would give a code? I've never used an OBD Diag. Tool before. G |
Gary
Posted: 13 Mar 2025 at 7:15pm |
Question for Steve. G |
steve(ill)
Posted: 13 Mar 2025 at 7:31pm |
dont need a code reader.. should get an idiot light on the dash if the hood is open or switch not working.. just like leaving the door open , or tail gate, or check engine light..
jaybmiller
Posted: 13 Mar 2025 at 7:32pm |
@TED J please do a test. open hood and try to remote start the truck. see if it does or doesn't start. curious am I .
steve(ill)
Posted: 13 Mar 2025 at 7:39pm |
If the light did not come on... then possibly something else prior to SLAMMING the hood... Yes, leave the hood open and try the remote start.. Also see that you get a LIGHT when you turn the key ON..
Ted J
Posted: 16 Mar 2025 at 12:44am |
There was no light on the gauges at all. I tried just pushing the start button without the brake being pressed, and no lights. Started and no lights. Opened the hood and it wouldn't start. I shut it like I always did and it wouldn't start. Kind of slammed it shut and it works. It was dark out, so I'll look later in the light to see if I can find the switch. Thanks!
DMiller
Posted: 16 Mar 2025 at 3:14am |
Ford is a little freakish as they like to put switches at the latches as well as contact points.
D19allisowner
Posted: 16 Mar 2025 at 2:25pm |
Some of the GM crap likes to put the switches in the latches so you have to replace the whole thing.
If you choose not to decide you still have made a choice.
Ted J
Posted: 21 Mar 2025 at 2:12am |
Due to our weather, I haven't been able to check this out. BUT,,,,yesterday I went to the store for groceries and lo and behold the 'check engine light' is on now. Ran the code at Advanced Auto and got a PO131. Says "O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)" So,,,,,,,,,,should I wait till it is warmer out and no snow on the ground and try to check the voltage at the connection? Just go ahead and change out the O2 Sensor? What are your thoughts? Thanks, Ted Oh yeah, this 2015 has 167,000 on it. I don't know if this has ever been changed. Should I change out both #1s (Bank 1 & 2)?
Edited by Ted J - 21 Mar 2025 at 2:14am |
DMiller
Posted: 21 Mar 2025 at 2:42am |
Change the failed sensor and await the next
steve(ill)
Posted: 21 Mar 2025 at 6:52am |
jaybmiller
Posted: 21 Mar 2025 at 7:26am |
I get those and a couple others(related) since going to a single cat per side. keep scanner onboard and reset when I'm fed up seeing the 'engine light' on. Since there isn't a 2nd O2 sensor,computer gets 'comfused'.....
steve(ill)
Posted: 21 Mar 2025 at 7:31am |
yes--P0131 is "RELATED " to the O2 sensor.. It is POSSIBLE that a squrrel ate the wire, or the cat converter is plugged/ damaged... but since it is a VOLTAGE related, the sensor is a good bet.
