Loss of brakes on a 7040
SilverShoes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverShoes Quote  Post ReplyReply Direct Link To This Post Topic: Loss of brakes on a 7040
    Posted: 10 Mar 2025 at 11:38am
Friend called said he lost his brakes on a 7040. He noted oil level is full, has hydraulics, power steering pto, basically everything except brakes. He is a state away so all I can do is ask questions. I’ve never seen this before on an a 7000/8000 series
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2025 at 12:33pm
If what he is telling you is true, there is an orifice on the inlet fitting on the brake valve. It is plugged with something. He should still have manual brakes of some kind. Verify system stand-by pressure at the JIC tee on the side of the PTO valve. Must be 300 psi MINIMUM.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverShoes Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2025 at 1:12pm
Thank you, I’ll let him know. He had to check those pressures on his 7045 pto so he will be able to check the pressure there on this tractor.
Edited by SilverShoes - 10 Mar 2025 at 1:14pm
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2025 at 1:22pm
Just to clarify what Doc said, the manual brake action is only at the bottom of pedal travel. Kinda like a car brake system at that point.
This page was generated in 0.053 seconds.
